Rotating or swapping Cup 2s left to right all arond
Tracked Emira
The track days have destroyed the outsides of tires due to the fact that we can't acheive better negative camber. Can someone please make an adjustable upper control arm made, other than Boomgear, which are quite expensive, especially with tariffs so we can dial in more negative camber.
I have 3 more track days and will switch to slocks next year as long as the rear parking system problem is solved by Kitkat so I can go to 18 inch wheels.
Can I swith left to right? Has anyone done this, and is it a good idea?
oh is there a fix for the rear parking system? whats the tire sidewall size for 18 inch is it the same?
As far as I know they are asymmetrical not directional. So you can switch them, but you have to flip the tyre on the rim instead of just swapping the wheels. Meaning inside stays inside, outside stays outside.
I guess you could do this if you run a lot on a track in the same direction.
Please fact check this, I didn't look up technical details
