And why is that, is it due to the weight? I tried to find a weight spec but didn't see one.I'd be keeping the OEM set as winter and these as summer IMHO -- that's just me.
I won't use actual winter tires, as I won't drive the Emira on ice or snow. I'll use a set of performance all seasons strictly so temperatures won't be an issue.If you need (or are obliged to fit by law in your territory/state) "true" winter tyres then the Lotus recommendation (excerpt from the user manual) is these :View attachment 31886
That's "BBS automotive GmbH", manufacturer of cast wheels. Minimal impact to the other "BBS" companies (there seem to be multiple).I read on the news BBS went bankrupt on October 2nd 2023
BBS has gone bankrupt about 5 times in the last 10 or 15 years. It's a constant refrain, but the company just keeps going.I read on the news BBS went bankrupt on October 2nd 2023
Those BBS look really nice, wonder what a set of bronze wheels would look like on a Seneca blue.
Maybe a bit too much like a Scooby?Those BBS look really nice, wonder what a set of bronze wheels would look like on a Seneca blue.
I did have a black one with gold wheels a while agoMaybe a bit too much like a Scooby?![]()
As long as you keep a pack of State Express 555 cigarettes in the glove compartment, the livery is legal on any marque.Maybe a bit too much like a Scooby?![]()
WeightsBBS suggested these parts and came in at 3k with my local supplier
CI6201AD02 2 STK
BBS CI-R Unlimited Grundrad 9x20 ET72
5x117,5 Schwarz seidenmatt Konkav. 0
59003161.2 1 STK
BBS Unlimited hub adapter 17mm 5x114,3
schwarz - 60.161 (Set 2 Stk.)
CI1701AD02 2 STK
BBS CI-R Unlimited Grundrad 11x20 ET70,5
5x117,5 Schwarz seidenmatt Konkav. 2
CI1701AD
59003060.2 1 STK
BBS Unlimited hub adapter 20mm 5x114,3
schwarz - 60.060 (Set 2 Stk.)
If those weights are accurate, that's terrible. You would literally be making the handling of your car worse with those kinds of weights. Here are the factory wheel weights:Weights
CI6201AD02 à 15,62kg
CI1701AD02 à 15,60kg
These weights are direct from BBSIf those weights are accurate, that's terrible. You would literally be making the handling of your car worse with those kinds of weights. Here are the factory wheel weights:
Emira front wheel = 8.5 x 20” +57 offset, 11.5 kg weight (25.35 lbs)
Emira rear wheel = 10.5 x 20” +54 offset, 13.5 kg weight (29.76 lbs)
15.62kg = 34.43 lbs.
