Guys, when you swap the ecu they will still know.. dont think swapping in and out will get your warranty warranted when you get engine related problems. They will see every rpm increase above 6800 and by default it is void. Our friend here had een problem with the engine/rpm related no need to go into details. Needed a brand new engine and it was not covered by warranty I can tell you that.
Once 3 years warranty is over id say unleash the beast, before that if you dont care about warranty.. but dont think doing all shit to the car and swapping the old ecu will cover your ass.. it wont!
Per your commentary, you could not raise redline.
Runtime will show gaps but absence of info isn’t proof of anything. Simply absence of info
Isnt vf tuner increasing to 7200/7400? It doesnt matter where the red color starts.. your car records the actual engine rpm not your dash rpm
He is offering to do so. I’m not talking about the red color or dash display.
I’m simply noting that it might be possible, for those extra worried, to leave redline as is
Im not worried nor caring about warranty hence shipping in my own ecu without a replacement swap. Im just giving info to the guys who think they can trick the warranty
There will be a lapse in the recorded dates if you remove the original ECU and replace it with a new ECU for a period of time. There's no way to explain that to the factory so it's better to plan on no engine warranty. For many, that won't matter but best to go in with that expectation.
