Key not in car
Daz205
Bristol
Hi,
I’ve been getting this a lot recently - have all updates to feb24 - seems to happen when someone opens a door
Is anyone else having same issue ?
My found cure is press unlock on key fob which seems to reset it 🤷🏾‍♂️
Putting key in tray recess doesn’t seem to help but unlock/unlock or unlock/lock/unlock does work reliably from the fob
Medic518
Palm Beach
Hi,
Low battery in the fob? Ive had that happen in a few cars. I've also had it happen when I've left the fob in the car on a brisk night too.
D
Daz205
Bristol
  • #3
Defo Not the battery already had that replaced
Lotus64
Midwest USA
If you have the key not in car error, try putting the key fob in the rear in the center console storage area (recommended by manual) or in the bottom of the rear most couple holder (recommended by dealer).
D
Daz205
Bristol
  • #6
Yeah that’s the tray recess I mentioned it doesn’t seem to do anything
I think it’s some module not loading or glitching more than the actual signal from the key
But that’s just my thoughts
Briggo
East Sussex
Hi - my daily key was becoming less responsive and often produced the "key not in car" message. Just had first service after 12m's ownership and 6k miles. Dealer changed battery last week since which, I have had no repeat problems.
D
Daz205
Bristol
  • #9
2nd key appears to work 👍
Thanks for the advice sometimes the easiest options staring at you and you don’t realise
