Intermittent delay when pressing start button to car actually starting
ttvetdoc
I have about 2000 miles on my Emira and I was in the first batch of cars to reach NA. Over the last few days, I have noticed an intermittent delay when pressing the start button. Instead of the car firing right up, it takes 1-2 seconds after I press the button before the engine fires. I'm concerned this may indicate an impending issue as this has never happened in the first 2,000 miles. I'll try to pin it down to whether it is consistent hot vs. cold starts, but just curious is anyone else has experienced this?
I feel like mine has always waited 1-2 seconds and I've never had a failure to start.
Mine does it as well. Sometimes it starts immediately, sometimes I have all the time to buckle up.
I experienced it after the update recall. It does not bother me as long as it is starting.
Built Feb 2023, 14.000 km on the clock
Same, always been like that. You can actually hear fuel pump etc immediately after pressing the button.
If you go Ignition on (press 5s) and then press again it'll start "faster". There is really nothing wrong, just systems getting ready.
Great! Good to know that others have experienced this and it's not a concern. It's just unusual that it occured all of a sudden after 2,000 miles. Anyways, I won't worry about it given that it's still starting up after the delay.
Getting this now at 2700 miles. Anyone know what the senses the clutch pedal/ or clutch actual position? If it a sensor on the clutch itself, I am thinking the clutch may need to be bled. I do not have any other issues, but this slow start does seem to happen when the car is very warmed up.
Whatever delay you think you are experiencing, it's not related to the clutch pedal. There is no lock-out on the clutch. Try it yourself: Put it in gear, foot on the brake, start and be ready to bob. Obviously don't do this in front of a wall / car / your grandma / etc.
If you want to tinker with it anyway:
Hmm why does the clutch have a potentiometer? That is for picking up position. Seems stupid if you can engage the starter with the car in gear and clutch out.
I've also started experiencing this also at around the 2000mi mark. I never put my car in 1st when turning it off (I know I should) so when I start it back up I just press the brake and it still starts. It was weird for me too when I discovered it at around 200mi, but pressing the clutch isn't necessary when starting the car up so that's what I've done since.
I don't know about Euro-spec cars (I see that you're in Germany), but this is not true for US-spec cars. If you're starting in neutral, all you have to do is press the brake, yeah, but if you're starting in gear, you have to have the clutch pressed in or the car won't start.
I'm gonna try it next time in the car. Since it doesn't make sense to not have this, they might have fixed it in one of the software updates I received since then. Last time I involuntary tested it was early last year haha.
I have a 2024 V6 auto and there is quite a delay from pushing the button to when the engine starts. It always starts eventually. Wasn’t always that way but it is noticeable. I have 6k miles
I also have a V6 auto and have noticed a significant delay also. Some days it's longer than others
My V6 manual does this. Seems to happen more on warm starts. Cold starts fire right up
Same here, V6 manual , 2,000 miles, delay started a few weeks ago.
Never noticed this issue before, but I have been getting this recently. 1900 miles V6 manual.
5k miles on my 2024 V6 man - mine has done this for a while, at different times. I always assumed it was fuel pressure and ambient temp related -- it never fails to start, but seems odd from all prior vehicles I've had. Overall it doesn't appear to be an issue to worry about is my current assumption.
I had a starting issue at 4000km (02/2024 build). Unlocking, jumping in, pressing the clutch, the car wouldn’t start. Aux lights and infotainment worked. I had to turn off, exit, unlock, and lock repeatedly before it started. It was a pain, but I did the latest update, and the issue has not come back.
