Going beyond 7k RPM: A Thread
Emissions and room for a "430 model" I would guess. What would happen if you plugged in an Evora ECU?!
Lotus are missing a trick not releasing a SW flash to unlock this. Basicially free money to them, not loosing it to a 3rd party. Could charge a premium and still offer a warranty. Come on Lotus!
from a purely slimy business perspective I would not release a SW flash and instead release higher HP cars in the hopes that existing Emira drivers will upgrade, especially those on a lease. after the Emira stops production then you release the SW flash to generate additional revenue on existing cars. This is why aftermarket has to solve this issue.
You guys are still under the impression that car companies have any freedom these days to fiddle with engines. Any change to a tune requires a very expensive certification process. The tune (via checksums) must be registered with the gov't and approved for use. If you want to make that tune available to earlier cars, you have to have those certified independently. For example, when Lotus came out with the LSS supercharger for the Elise, they had to get separate certifications for each model year prior to the 2008 cars, which had it as a factory option.
In the US, California basically sets national policy because it's the biggest car market in the US, and it's uneconomical to have CA and non-CA cars (and also difficult because you have to ensure they don't get sold where they're not supposed to). In Europe, I'm less familiar, but I've had dealings with the US regulators and I have a low opinion of them. Zero interest in practicality, zero interest in fun, no understanding of car technologies, and just a mandate to crack down. They will never say "we're done, good enough" because that means less hiring, fewer promotions, and less to brag about with accomplishments.
Modern EFI engines, those designed after the early 2000's, emit cleaner air on a smoggy day than they take in. You can't squeeze blood from that stone, so now they're looking at CO2 levels. Direct injection is a result of reducing CO2 levels because you can be a little more efficient at low load, at the cost of being dirtier at high load. Well, now, the direct injected cars are going to have particulate filters, like diesels, and they'll need urea tanks to help clean the filter, which will harm mileage.
I'm really thankful for the Emira's primitive engine. It's the best "old car" you can buy today. More RPM would be nice, I got accustomed to my Elise screaming up to 8500, but it's also nice to have torque instead.
I think if you're really set on high RPM, the best solution would be to buy a Cayman GTS.
I did a factory tour back in October of last year and spoke to the V6 engine engineer. He said that they extracted the most power and rpm's possible from this engine without it coming apart. During their tests, if they applied any additional power/rpms they had engines coming apart. In order to add additional power, would require upgrading the engine internals as they did on the Evora GT's. The GT engines have been upgraded and are not identical to the Emira. This is what I was told.
The Lotus Emira GT4 has 460 horsepower
The GT4 has a different supercharger, and different engine internals that aren't economical for a street car, and it doesn't have an emissions system to protect with a conservative tune.
The dealership where I got my Emira has a GT4 for sale as well, for more than double the price.
Yeah for sure. I think people are truly dreaming that the Emira will get a 450+ engine here in the states. If lotus wanted to, they would have. They can’t with emissions. The cost of doing so wouldn’t justify the cost. Theyre bleeding money. Ex US have a chance at getting higher HP cars just like the got the Evora 430, etc. Thankfully we are starting to see aftermarket create some tunes. Now if they didn’t cost 5k+…
You are correct!
My auto revs only to 6,500 and the dealership called Lotus about this and they said this is the safe parameter so the motor doesn't develop any issues. I can understand that, but then let your customers know the new RPMs and change the 0 to 60mph times because it will not be the same anymore..... BOOOOO!!!
You are correct!
Not at all...Not necessarily. This engine is great for rpm. But delicate. Ecu and tcu unlock then springs help plus valve and cai and dekat
I personally do not think the Evora GT had a different engine with different internal part. Never heard or read about this before. Our car can safely rev til 7200rpm and make 416-430hp without any additional bolt on part and risk to explode under normal operation.
Lets hope pray for a good affordable reflash tune from Greg’s, sector 111 or boe fab one day…
Thank You California emission regulations.👎
Considering this for my vanity plate. Apparently it is available.
I think it's very unlikely that the Evora GT cars had different internals for such low volume cars and a modest increase in power. The engines already have forged rods and cranks from the factory but make do with cast pistons which ultimately limit the amount of boost that can be supported.
We know Lotus struggled with EPA regulations at the eleventh hour and that delayed the US introduction of the Emira. All signs point to ECU remapping as the solution to those problems and there's a good chance that Lotus had to sacrifice a higher redline to meet stricter international emissions prior to that.
Jubu and others have shown that there is more power and higher RPM's available at the cost of emissions. In fact, they intentionally limit output to 500NM to ensure reliability. Other manufactures including Ford offer factory tunes but I doubt Lotus will given the associated regulatory costs and far lower volume of production.
Hi there. My experience convinced me that it's a pity that this bloody engine is limited in rpm. On dyno the power still increase after 7k with cai dekat and ecu tcu. After that, the cooling system is weak, and the rods too. But jubo has excellent springs and valves, not expensive, to get minimum 800 rpm more
Wild: Supertech kit by Frankenstein Motorworks - Good to claimed 8300rpm with standard lift cam. Includes retainers and caps.​
Unknown: Supertech dual valve springs - unknown specs, part number SPRK-EC3025D-2GR. Very high end product, may be very high performance. No longer in Supertech catalog, but exists in fulfillment warehousing. Needs investigation with Supertech to determine complete spec.​
Hope this helps to open up the topic for discussion. I'm interested to see what others discover, attempt, and achieve.
I had supertech valves and springs on my previous built engine RS3 running 650-700hp. They were perfect and the recommended product by several engine builders for that platform running inn excess of 1000hp. Different product but shows they are capable of producing quality products.
I thought the limiting factor for RPM and torque was the rods?
Do you guys know if there are any videos of people who have modded their Emira's or Evora's to achieve high RPMs with aftermarket valve springs? I'm curious what the car sounds like at 7-8k RPM.
A coffee can full of metal marbles when a valve contacts a piston
Frankenstein Motorworks is one of many companies that have done significant development work and demo different builds out of the 2GR platform. There's also a good amount of 2GR's being fielded in many forms of racing for one to follow as well.
Personally, I find the 2GR to be quite robust and there's decent amount of data out there for one to look over and decide for themselves.
I would love a few hundred more RPM's. Reading through the thread it seems there's some debate whether the Emira version of the engine can reliably handle it or not. If the ECU gets cracked it should be a trivial and cheap exercise to increase the rev limit a few hundred RPM.
Coming from a high reving Porsche my first few months of Emira ownership involved smashing into that brutal rev limiter on multiple occasions. I've had to recalibrate my brain to 'short shift' and ignore the sound which tricked me into thinking it was just starting to get on song.
Yeah. I don’t shift by shift light. I shift by engine feel and engine sound. And the v6 pulls even harder those last 500rpm so it fools me into staying in throttle too long and I end up banging against that limiter.
I bet if you raised the limiter the engine wouldn’t nose over till around 7200.
It’s like they left the same cams installed that were for the Evora and just imposed a shorter redline. :(
