Engine radiator burst !!!
40.000km V6 and this did not happen to me, but I had all sorts of leaky hvac ducting and a badly welded radiator replaced, around 25.000km I think
I'd be suspicious of over pressurising, ie, head gasket, cracked or porous casting or similar.
You can see the fibre reinforcement strands all busted..that would take some doing with a system that shouldn't be exceeding 20psi
I'd be suspicious of over pressurising, ie, head gasket, cracked porous casting or similar.
That was absolutely my first thought. Manufacturing fault in the pipe perhaps? Although with how many of these there would be out there.. just doesnt make sense. Isnt the engineered failure point the cap anyway?
Update for mine - Just got it back, replacement of the hose, no other issues found after refilling the coolant system. The dealer did mention this particular hose has failed in a couple of different ways that he is aware of. And all done under warranty
