I noticed that also, I am not sure what the cause is.Not that I care in the least, but curious, why the EPA milage estimate is lower on the Emira than the GT??
interesting, also note the Evora GT 416HP vs Emira 400HP, so that might change the smog numbers.It's also interesting that the Emira has a better smog rating. The difference in gas prices from then to now really cranks up the fuel cost estimate.
You know I see that the sticker says 400hp but there are folks in the USA that have Dyno tested their cars after break in and were getting slightly higher numbers than the manufacturer states. Not huge but right at 416 crank based on the higher wheel numbers.interesting, also note the Evora GT 416HP vs Emira 400HP, so that might change the smog numbers.
I haven't seen this. What are the dyno numbers?You know I see that the sticker says 400hp but there are folks in the USA that have Dano tested their cars after break in and were getting slightly higher numbers than the manufacturer states. Not huge but right at 416 crank based on the higher wheel numbers.
J | Design 101: comparing the Ferrari 308 | Lotus Emira Talk | 46 | |
Look up Window Sticker online? | Lotus Emira Purchasing | 0 | ||
D | ❓ QUESTION Window opening from remote | Lotus Emira Questions | 2 |
