Best Alignment Settings for Sharper Turn-In & Heavier Steering on Emira?
luciddaydream
howdy everyone,
I’m really enjoying my Emira but want to fine-tune the alignment to get sharper turn-in and a heavier steering feel.
From what I’ve been reading, adjustments like front toe-out and more negative camber (within factory limits) might help. Before I take it to my shop, I’d like to hear how best to word the request so they know exactly what i want.
Has anyone tried:
  • Switching the front from factory toe-in to zero or slight toe-out?
  • Maxing out negative camber up front (around -1.3°)?
  • Dialing back rear toe-in from the factory setup?
I’d love to know how you explained these changes to your shop and what the real-world results were — especially in terms of steering weight, response, stability, and daily drivability... thanks
PS: Sorry I am new to the lingo and stuff above. I also have the sport suspension, but the Michelins.
I've gone to max negative camber and zero toe in front. I like the results. Definitely reduces understeer. Also, I run the tire pressures at 4psi difference front to rear. (26/30 cold). Rears always heat up more and will result in about 5psi difference when hot. Helps the understeer.
I wouldn't go positive toe in front as it will become darty. I also leave rear toe alone. It seems fine with the above changes and I want no possibility that it could ever reach a toe out condition under heavy suspension movement.
Depending on exactly what you mean by sharper turn-in, changing toe will do a few things. More toe-out will reduce front end response right around center steering. This reduces self centering force right around the center though, so it can actually make a car feel more responsive, however. These are pretty subtle changes though and mostly what you are looking for is a smooth transition across the center and a tiny amount of toe-out is generally recommended for this. My guess is that Lotus specced a little toe in for the cup 2s because that makes them feel a little more responsive when someone does the little wiggle test and many people think this is a good thing. I would just keep toe where it is on your car. I wouldn't touch rear toe either.
Increasing camber gives a similar effect to more toe in because of camber thrust, but it's not as pronounced, especially with the small camber changes we're talking about here. So it’s not going to change steering feel much, but if you plan to do any track days, maxing out camber will help with front end grip and even with street driving it will probably help with tire wear if you corner somewhat quickly. I tend to wear out the outsides of my tires first and I’m not really cornering that much faster than a normal driver would on the streets. Nowhere near the limit in the Lotus.
I mostly recommend you try running more caster. Maybe ask the shop to give you a degree to two more and see if you like that. This will give you increased steering effort throughout the entire range, and not just around center like toe/camber. Not sure how much adjustment range the car has though and it might limit how much negative camber you can get as well.
Here's an article I did a couple years ago that goes over steering feel.
Thank you!
More caster is key. Here’s what I run on the Evora, emira should be very very similar.
I very much agree with Mike.
Adding front camber will increase overall front grip, but at the limits of camber adjustment you will need to sacrifice some caster. If you are hunting steering weight, I don't think you will want to reduce the caster.
You will also probably want zero toe up front to improve that responsiveness feel on center.
Really helpful info on this thread, thanks for that.
Good timing for me as well because I went to the garage to have the wheel alignment reviewed yesterday, ahead of my next track day. Perhaps it’s helpful for everyone to see what the before and after measurements were from the fancy machine they have.
My car is one year old, has done 6000 miles and two track days, it’s on touring suspension… Some of the before alignments are not symmetrical, perhaps that’s just from usage. But there have been no adjustments from the factory so before measurements are considered ‘stock’ plus one years worth of usage.
The after measurements show the most negative front camber and positive front caster adjustment that the mechanic could get out of the existing stock parts (he didn’t touch the rears)
Hopefully that is insightful for anyone else considering the same things :-)
I’ll feedback how the changes handle on track later this week.
Before
After
I have ~250 mi on my 1-wk old car with tour suspension. The alignment is off. I can feel the toe is noticeably off, I cannot tell if camber or caster is off from left to right. During the first service after break-in I will have it aligned as well.
