Trying to consolidate this information cause things are getting confusing:
THE PROBLEM: OEM Exhaust Valve controller and/or associated wires are melting causing Emira to go into limp mode.
REASON: High temperatures near the exhaust area from one or more of the following...
1. Titanium Exhaust (Primary reason but not all Emiras with titanium exhausts are having this problem)
2. Aftermarket diffuser without the vent that is present in the OEM diffuser (Contributing factor)
3. Tracking the car for extended periods on hot days. (Contributing factor)
SOLUTION: One of the following...
1. Don't get a titanium exhaust. Opt for an insulated/wrapped stainless steel exhaust instead. Problem most likely solved.
2. A
working Milltek Valve Controller would solve this problem because it intercepts ECU communication with OEM Valve Controller. Even if the OEM Valve Controller malfunctioned, the ECU would not know. So, you can still use titanium exhaust if you have a
working Milltek Valve Controller.
3. If you don't have or want to use the Milltek Valve Controller, you can get a OEM Valve Controller relocation kit to keep it away from heat.
4. A ventilation kit,
like the one in this link, may or may not solve the problem but would definitely help.
Is this correct?
If you get the relocation kit, does the OEM Valve Controller still function?
If you want to keep the titanium exhaust, and you have a working Milltek Valve Controller, is there any reason to get the OEM VC Relocation Kit?
