Just got the Mega Matt and Ill be installing when I get my fabricator to extend the Aerie tips. Hoepfully removes the boominess on the higyway and reduces trunck temps. Mind you the mega matt isnt light. Thanks for all your input.
Make sure you have the high temp foil insulation tape, to tape up the joints and seams.
If you've ever handled Dynamat or some of the other brands, you'd appreciate how light the Mega Mat actually is.
The resonance boominess is most noticeable at 2,000-2,300 rpm which unfortunately is where the rpm sits in 6th gear at freeway speeds. After these mods, it's only really noticeable if you press the gas pedal when it's in that range. As soon as the rpms get above that range, the resonance stops. At a steady cruising speed, it's not bad. I'm going to keep exploring and see what exactly is resonating at that frequency to see if I can isolate it. Typically when I've dealt with this issue on cars in the past, it was the trunk cavity that was the culprit.
Okay, as I was typing this I realized I hadn't actually done any sound tests on the trunk because the Emira's trunk isn't that big. So I just now went into the garage, and using a rubber mallet, began testing the bottom of the trunk and sure enough, it sounds boomy! especially on the passenger side. I'm going to check in the manual to see if there's any particular trick to removing the carpet on the bottom. I bet some Damplifier mat on the bottom will stop that resonance completely, and that might do the trick!
Energized by this new discovery lol, I went out to the garage and did some work. Here's a sound test using a rubber mallet and tapping on the left side, middle, then right side of the bottom of the trunk: The passenger side clearly has the worst amount of resonance. (You can hear it best with headphones).
I removed the carpet which is easy (you just lift it out after removing the battery cover, and the two road kits velcroed in the back). There's a large flat piece of plastic on the bottom.
I cut 3 pieces of Damplifer mat and placed them across the bottom. This is the left side to show the size; they're one foot wide.
Here's the sound tap test after installing the Damplifier mat. It's better, but you can still hear a slight amount of resonance on the passenger side which originally was the worst side.
It looks like the plastic bottom of the trunk well is bolted onto something underneath, which has to be metal of some kind since it's above the muffler. I'm going to do a road test to see what effect this has made, but I won't be able to do that until tomorrow since its raining and windy outside right now. It's supposed to be clear and dry tomorrow, so I'll report on the results then.
Took the car out today. The resonance was definitely lowered by the Damplifier on the bottom of the trunk well. I even deliberately drove around in different gears, holding the rpms at 2k-2.3k, and I'd say it's now about 98% reduced. The resonance seems worst in Tour mode, but definitely not as much as it was. Even with the Damplifier mat, there's still some resonance though. I know there are some who've removed the lower back of the car, so I'm going to have to look at how much of a hassle that is if I'm going to go further in nailing this down. It seems like there's something under the trunk well that's resonating too, so I'm not entirely sure if it's the trunk well itself, or what it's bolted to.
It could also be that at my age, I've become more sensitive to lower frequencies than I was before. At any rate, it's much better now than it was.
OK so to sum up,
1. Youve extended the Aerie tips another 1 to 2 inches rearwards.
2. installed the Mega Matt (or was it megablock????) and
3. Damplify in the boot
Great effors @Eagle7.. thanks ill be following your guidance once the whole R&D phase is completed 💪🫣
OK so to sum up,
Yes, and it was Mega Mat. I installed 3 pieces of Damplifer mat, about 12" wide and 6" tall across the bottom of the plastic trunk (boot) floor. I've continued to check and by tapping on the vertical engine side of the boot, I can still hear a hollow sound, so I may remove the carpet on that area and add a few more pieces of mat.
Are these from GRP? And does the size fit if you have the grp spacers? @GRP
Those are not from us although we do have titanium lug bolts coming soon -- extended length with floating seats like the oem bolts have.
I've had my Eventuri air intake for about a year now, and I decided to clean the filter. There's no easy way to do it. You have to remove the entire unit from the car, which involves pulling the connecting tube from the supercharger inlet and the Eventuri, and disconnecting the MAF sensor.
Once out of the car, take note of the following:
There's a big thin rubber band-like seal that goes around the connecting seam of the two body halves. Carefully lift and move that back on the body, or if you want to remove it to clean it (which I did), make sure you put it back on the correct half and side of the body.
To take apart the unit, there are 3 screws you need to remove (you can see two of them above) on the metal tabs that connect the two body halves. The screws have an 8mm lock nut underneath, so you'll need an 8mm wrench to hold the nut while you unscrew them (you can reach them from inside of the short half of the body). There are small black plastic washers that go on each of these screws, so keep an eye on them so they don't fall off and disappear somewhere.
After you remove those screws, you can separate the body halves. The long half holds the filter, and you'll see 6 screws that need to be removed (I've already removed them in the photo below). Take note of the order of disassembly here; the mounting bracket goes on top, the round collar disc is under the bracket, and they sit on top of the filter. When reassembling, the mounting bracket goes over the collar disc, not under it.
This wide hard plastic ring in the picture below is actually the top of the filter. The filter construction is very solid overall. When you lift the filter out of the body, there's a very thin, soft and flexible rubber gasket between it and the body that's easy to tear, so lift slowly and carefully. Half of mine was stuck to the body, and the other half was stuck to the filter. I removed it completely before cleaning the filter. It's VERY soft. In the picture below you can see some of it squeezing up through the screw holes on the filter.
After carefully removing the filter so as to not tear the gasket, now you can clean the filter.
They recommend you use compressed air to blow out the dust from the back of the filter, but I didn't have compressed air, so I just used warm water and the spray pattern from the nozzle in the sink. When I first removed the Eventuri from the car, I had a feather and a piece of hay in it lol. There weren't any bugs though, which was good. I was surprised at how much dirt and dust washed out of it. I've only got about 2,500 miles with it in the car, but that included a long 700+ mile trip. After the initial rinse out, I sprayed filter cleaning solution on it (@GRP sells the filter cleaner kit. Even though it includes spray oil, DO NOT use the oil. The Eventuri uses a dry filter and just needs cleaning). I let it soak for a few minutes, then used warm water with the spray nozzle to rinse out the filter. Even more dirt came out with the cleaner solution. I spray rinsed onto the back of the filter until there was no more soap coming out the front, just clear water, then let it air dry.
Reassembly is the opposite of the above procedure, however, if you removed the big rubber band that goes around the body, put that on first before you reassemble the filter pieces. Take care with that thin gasket between the filter and the body. When reassembling, MAKE SURE it clears the holes the screws go in before putting in a screw, because the screw will grab and twist it up otherwise (don't ask me how I know). Put the gasket, the filter, the collar ring and the mounting bracket all on top of each other first, then put the screws in. I kept everything slightly loose, so I could lift the filter edge just enough as needed, and used a small allen wrench inside the hole to push the edges of the gasket out of the way of the screw hole. Once it's out of the way (you may need to do this for each of the 6 holes), lower the filter to hold it in place long enough to get a screw threaded. Don't tighten any of them down until all of them are threaded.
Once they're all in place, FINGER TIGHTEN them using a star pattern, going crosswise like you do lug nuts on a wheel. They only need to be snugged down finger tight, don't crank them down. Also, before you put the screws in, pay attention to the orientation of the mounting bracket (see picture below) so that the wire loom is below, and the tall bracket tab above is aligned with the MAF sensor.
When reattaching the other body half, make sure the drain hole (you can see it inside in the picture below) is on the bottom facing down. Reassemble the 3 tab screws (don't forget the black washers) with the lock nuts, and again, just snug them down; don't over-tighten or you risk cracking the carbon fiber. The last step is to pull that rubber band around the body, over the seam (see first picture above) where the two body halves meet. Now you're ready to re-install the Eventuri back in the car.
Excellent tutorial!
How would you summarize your Eventuri driving experience so far? Worth the modification? Thanks.
Excellent tutorial!
Yes it's definitely worth it. Despite being a pain to clean the filter, the increase in power and torque can definitely be felt. It's a shame it isn't visible though, it's such a nice looking unit!
Hey @Eagle7 any more updates? Doing anything else? Are you considering the JB4 unit to lower even more the P/W ratio? Considering Tillet seats? Did you ever do any more sound deadening?
Curious minds.....
Ryan G
Curious minds.....
Ryan G
I have several that I haven't posted because they weren't anything spectacular. I upgraded the steering wheel buttons to the push buttons which I like much better than the haptic buttons. I also got a floor mat for the trunk.
I have the JB4 installed and been running it on Map1 for a week. Unfortunately we don't have 93 octane where I live, so I can't test Map2, but I have an appointment Monday morning to get a dyno for Map1, and I'll post that later on Monday. I'll also post some pictures of various things. I've been slow to do much because of the heat and humidity. We didn't have much of a spring, it just went hot and has stayed that way. Heat, humidity and being old don't go well together lol.
I'm not going to do the seats. I don't have a problem with the factory seats. I guess my body proportions are about right for them, as they don't cause me any difficulty.
My next project is to get the CCB brakes installed that have been sitting here in boxes for months. At that time I'm also going to remove the wheel well liners and put sound proofing on the backs of them. I can only do things very early in the morning, like starting at 5:00 a.m., and I have about 3 hours before it starts to warm up. I'll just have to get started and chip away at it until I get it all done. Being old really slows you down.
Come on Eagle, do the seats. I would lay money down that you find it makes way more difference to your driving experience than all the wheels, exhausts and light batteries combined. Every time the dealer gives me a courtesy car I hate it. You sort of bounce up and down on the cushions, the spine collapses into a hole in the lumbar area and you fly off the sides when you corner. And you sit right up high like a pimple on a pig's bum.
You are my spirit animal good sir! I wish I had the mechanical know-how you do so I could do these things myself, but sadly that is not the case..
I really want to do the Clutch and trans fluid when I do the oil change in the next couple of weeks, but honestly I have read a few threads and watched videos and I just can't do it.. I might need to just pay the dealership to do the trans and clutch when they have it for all the updates and such.. They are just so expensive!
Ryan G
Your seats are going to be something I do at some point (when they fix the warning light probably).. I hate how high I sit in the car and the padding / bladders are terrible..
I do want the pads to be ice grey though.. Not sure if you were able to get that color for the pads or not though.
I won't highjack Eagle's journal though..
The warning lights are no longer on my car. I have the JUBU resistor plugs which work perfectly on my UK spec car and Greg says he has sorted it now too.
I'm not sure if my factory has done an ice grey set yet. but I cannot see a problem there. Leather colours are easier than Alcantara to match.
There are a bunch of us over on our side of the pond that are still waiting. Greg's last public post (fairly recent) was that he had a friend chipping away at it, but no cigar to date.
Trust me when I say, there are many people waiting for this fix in order to buy CF bucket seats. It's probably the number 1 thing I miss from my 991.2 Carrera T. Those seats held you in place unlike the OE couches that came with our wonderful Emiras. If you have a fix for the North American passenger seat market, I would put it on a website and you'll see you'll likely sell-out any first batch you commit to. Heck, do a group buy. I know I personally would pay in advance to ensure the first round delivery.
