AC Issue
SJ4
My AC has failed and is blowing cool to Warm air.
Background: Purchased car (2024) in March. On delivery day I got 15 miles up the road and noticed I wasn’t getting cold AC. Took it back and they found a Schrader Valve leaking. Their fix was to replace both HIGH and LOW Schrader valves. Dealer then shipped the car to me as I live 3 hours away.
I haven’t been able to drive the car much since April and it hasn’t been hot until lately.
Now the car AC is not working. All the electronics are ops normal so I believe it is a slow leak. Since it did go from ICE cold (after the Fix) to cool/warm and now unbearable now that it is 88 degrees outside.
Today I recognized that the driver side vents (Left and Center) blow air warmer than the passenger side (Center and Right). The AC is still not blowing cold air, but I can feel a cooler (Less than warm) air coming from the PAX side….
Can anyone tell me why that would be? I am trying to figure out as much as I can before I bring the car in for warranty AC work on Monday.
Thanks.
A/C Resistor Fix Done at Lotus Dealer
I had a similar A/C issue on my March 2024 delivery FE Emira, with around 1,000 miles on the clock at the time. Like you described last July, it happened on one of the hottest days here in Central Ohio. I took it to the local Lotus dealer, and they said they installed a resistor as a fix. It seemed to resolve the problem.
However, about a year later—during a one-hour drive with a few stops on another hot Ohio day—the A/C temporarily switched from cold to warm for about 10 minutes, then corrected itself and started blowing cold again. I’ve driven the car several times since without any issues.
The only thing that stood out was that I had been driving a bit more spiritedly just before the A/C started acting up. Not sure if that’s related, but figured I’d mention it.
Thanks for that info. I was ruling out the resistor fix as mine does have that and the latest software. But, now maybe mine could be acting up. I have a3 hour drive Monday so it will gave it time to maybe turn back on or totally fail hot 🥵
My car is still at the dealership looking for AC leaks. It seems everything mechanical is working. But they are searching for a small leak.
Does anyone have a diagram of where all the AC lines run from the front to the rear? I would like to be able to picture what route the AC lines take through the interior to the compressor.
Thanks!
My Emira i4 also has no cold air coming out of the air conditioner. The cause was a gas leak from the condenser for heat exchange. This problem seems to have existed since the Evora. I ordered the condennser from Lotus' headquarters in the UK from Japan about a month ago and received it last week. And today, it was installed on the Emira.
Good info Khiro. Thanks.
I was told yesterday they found a leak in the line that connects with an O-ring that is located in the wheel well .
They we able to access the line by removing the inner liner.
I am hopeful this is the cause of my AC Failure. I know it was a slow leak as I had the car for about 3 months before the AC failed.
After a month in the shop the leak is fixed. Of course, I will keep monitoring since the last leak took 3 months to fail.
They found that the lines in the right wheel well leaked and needed to replace the o-rings.
I had a AC vent temp gauge hanging around so I drove the 3 hours home from the dealer. The lowest temp out of the vent was 46.7 F. It seemed to vary between 46.7F and 55F. About 2.5 hours into my 3 hour drive the vent temp reached 59F. I assume it was due to the sun not blasting in the windows and the car was nice and cool/cold.
Also, the outside temp was about 95F and not 100F as the Dash indicted. I see the dash indicator always shows 5-10 degrees high.
If anything changes I will update this post.
