3.5L engine removal process
I think so. I can't be sure of the Emira, but in the Evora, Lotus buys the transmission stock, and then replaces certain gears to get the ratios they want.
From my understanding, motor is untouched except for adding super charger, transmission is rebuilt.
Woah.. do you know, or can you find out how many hours they will charge you just to disassemble & reassemble?
A UK user on here posted that the booked time for engine out and a replacement clutch bearing being fitted was 22 hours. That time is stated by Lotus but I'm sure dealers will take longer if they haven't done it before.
Yeah, usually book time is based on the third time a repair is performed by a tech. Source: Had to go to a lot of service management classes.
26000 miles. Apparently it was down to my driving style. I’m overdue doing an update on this in my journal.
Thanks. How do I see your journal? Mine had done just 500 miles and was making a huge noise from the clutch/gearbox. It’s been back at the dealers for 3 weeks, but I’m still non the wiser as to what the issue is, despite chasing them every 3 days or so.
Man, every time I think about "maybe I'll do a built engine...." I come back to this pic and go oh yeah, I'm not ready to go Full Send yet.
Do you think Laika felt ready when the bolsheviks blasted her into space?
Did @mikemc feel ready when he skipped a whole blower upgrade and YOLO’d to the 2300? Was washington ready when he crossed the Delaware?
TLDR: forged pistons or death!!
But what about the cake?!
Laika had protein gel, I believe.
Mike however could be into cake, I can’t say.
I I haven’t had good results with cake pistons but ymmv and love the outside the box thinking!
It's clam off and then some.
IDK on the Emira exactly, but the Evora is clam, hatch, rear bumper, sail panel off. Disconnect ECU and wirings to/from battery (and remove battery) Remove the mentioned above. Remove riveted heat shield. Clamp all your coolant hoses, disconnect exhaust, remove alternator, remove AC compressor (leave in car so you don't have to drain), remove power steering pump (so you dont have to drain), disconnect/clamp trans lines. Hookup engine hoist and disconnect the 4 motor mounts. Lift her out.
There's probably some nannie I didn't mention off the top of my head.
Then do all the "while i'm in there's" lol
