Windshield washer
Jbrock
Today, my windshield washer stopped working. Checked fluid, topped it off. Anyone else?
Is it making any sound? Do the wipers work? If nothing is happening at all, might be a fuse.
I had this issue with mine (never worked) and I had my mechanic check it out and they said if they knocked it it would fire back up.
They were gonna order a new pump but oddly it just works now.
You could check the connection to make sure the connector is plugged in correctly. Check the hose lines; check to see if there are any air bubbles in the line between the fluid reservoir and the pump. Is your dealer close? If everything is connected and looks okay, it might be a bad pump which is covered under warranty.
I habe this example issue now after 33000km, worked fine before.
Nozzles are clean, doesn’t leak and reservoir Level doesn’t change, so I would guess its the pump, connection etc
