What RPM for cruising around?
RyanGphoto
So I notice that around 35mph in 2nd gear I am right at 3,000 rpms and at roughly 46mph I am at 3200rpm or so.. My question is..
What rpm range do you just cruise around town.. do you shift when you are near or above 3,000rpm? Do you wait until 3500rpm? 4,000rpm? I feel like driving around at constantly 4,000rpm sound loud and feels like it's straining the engine (I could be TOTALLY wrong here). Just curious what you guys do?
Thanks
Ryan G
4th gear for 40-50MPH. 2000-2500 RPM
I feel like 2k-3k is the ideal cruising range around 40-50MPH
Reactions: ADC
Something interesting that a lot of people probably haven't noticed (took me a while to notice, at least):
Right near where it shows you what gear you're in on the instrument cluster, there appears a little up-arrow to indicate when you should shift up under normal/cruising driving conditions. I'm guessing it's meant to be optimal for fuel efficiency since it appears at surprisingly low RPMs (even lower than what feels natural).
For the V6, normal driving around town is about 2-2.5k if I am maintaining constant speed. My old manual habit is to select the gear that matches the speedometer/10. So so if I am accelerating from 25 to 35, I choose second gear and shift to stay in third gear when I am done.
Lower than 2k, I feel like the engine can be lugging a bit, plus you get the manual transmission lashing sound below 2K. Above 3K, just driving around, on/off throttle will jerk the car a bit too much to my liking. I can't imagine driving around at 4K for constant speed cruising. I would only be doing it if I had downshifted and is waiting for a chance to change lanes and speed up.
Not hugely dissimilar from my rule of thumb - my brain aligns gears (at cruising speed) to the common speed limits over here:
20 -> 2nd gear
30 -> 3rd gear
40 -> 4th gear
etc
This simple mental mapping is nice and easy IMO.
Basically I just aim for not being a noisy berk around town, and not lugging the engine. Of course, once I come to a 50+ zone that isn't built up, it's often 2nd gear to redline, and then a brief shuffle through 3/4/5 to cruise again 😅 😁
Cruising around FL normal roads I try to keep the revs in-between 3k-4k once the engine is warmed up. It just seems to be the sweet spot for sound & power with this engine. Highway just row out to 6 and chill.
Just drive it everywhere.. that's how I got all my miles.. .
Where in NJ are ya?
Dude I’m trying but I commute via ferry and I have my son on weekends. Having son necessitates we use the fam car (cls53).
I guess I have a thing lately for blown 6s
I live on waterfront in Weehawken/hoboken area
Grew up in Jersey City, but living in FL now.. Headed up that way end of the month to see the family, but won't have the car sadly.
North jersey meet up? 👀 I'm about 20 minutes away out in West Orange
I don't drive it often, and not concerned about fuel economy, so usually hanging around 3-4k (unless just cruising on the freeway - then 2kish). It sounds so good at 4k that I find it hard to resist.
Having an engine run at 4k vs 2k will produce twice the amount of wear on some components, but who cares? I change my oil often enough and this is a Camry motor after all - it can probably go 200k with the right service intervals.
