Hello everyone,
I'm hoping to get some assistance with a couple of persistent air conditioning problems on my 2024 Lotus Emira. Unfortunately, as it's a grey import, I don't have dealer warranty support, so I'm trying to diagnose and potentially fix these issues myself.
I've already started some basic troubleshooting, and here's what I'm encountering:
Problem Description:
Regardless of the setting I select on the climate control (face, defroster, etc.), all airflow consistently comes out only through the footwell vents. I cannot redirect the air to any other vents. This suggests an issue with the blend door that controls airflow direction.
Troubleshooting Steps Taken So Far:
My Suspicions:
I strongly suspect these unplugged sockets are meant for blend door actuators (flap motors) that control the air distribution. The 12V on the black socket supports this, as actuators require power.
My Specific Questions for Experts:
Despite setting the A/C to "cold" and turning on the compressor, only hot air blows. The A/C compressor does not engage at all.
My Suspicions:
The fact that the compressor clutch didn't engage even with direct 12V worries me and suggests a potential issue with the clutch itself or the compressor's internal mechanics (e.g., seized). However, I understand there are many other interlocks that prevent compressor engagement.
Any guidance, diagrams, or personal experiences with Emira (or similar Lotus HVAC/AC systems) would be immensely appreciated! I'm an experienced DIYer but facing challenges without official documentation for such a new and niche vehicle.
Thank you in advance for your time and help!
Issue 1: Airflow Distribution Stuck on Footwell Vents
- I have removed the glove box to inspect the HVAC unit.
- During inspection, I found two unplugged 3-terminal electrical socketshanging freely behind the glove box, near the HVAC box:
- Socket 1 (Black): Contains wires colored Black, Red/Green, and Blue/Green. I measured 12 volts present on this socket.
- Socket 2 (White): Contains wires colored Black, Green/Red, and Green/Blue. (I haven't tested for voltage on this one yet.)
My Suspicions:
- Can anyone help identify the precise location(s) on the Emira's HVAC box where these specific 3-terminal sockets are meant to connect? I'm looking for the blend door actuators responsible for air distribution (face/foot/defrost modes).
- Are there any known diagrams, photos, or service manual snippets available online (even for older Lotus models if they share similar HVAC layouts) that show the typical locations of these "mode door" actuators?
- Is it common for an Emira to have these connections left unplugged from the factory, or is this unusual?
Issue 2: A/C Compressor Not Engaging (No Cooling)
- Direct 12V Applied: I applied 12 volts directly to the compressor clutch wire. The clutch still did not engage.
My Suspicions:
- What are the most common interlocks/failure points I should check before concluding the compressor itself is faulty, especially if it didn't engage with direct 12V? (e.g., specific fuses, relays, pressure switches).
- Can anyone provide the location of the A/C compressor clutch fuse and relay for the 2024 Emira (or similar Lotus models if known)?
- Considering the direct 12V test failure, what is the likelihood that the issue is still a low refrigerant charge, or a bad pressure switch, rather than a completely dead compressor clutch/compressor? (I do not have AC manifold gauges yet to check refrigerant pressure, but that's my next step.)
