To stripe or not to stripe?
I did subtle hood, trunk and front sides stripes, post-ppf so can easily remove if desired.
Thanks, happy you like it, feel free to order, here's the info I have to help... I had the dealer send it out to a third party so I don't know what the actual stripe material was (ppf or vinyl). They got a bunch of yellow samples, matched it to the factory mirrors, then ordered bigger sheets, then cut it to the thickness and distance apart I wanted. The clear wrap that went on first was Llumar Valor. I'll be seeing the dealer later this week and will ask about the stripe color name and material if they know.
Reactions: TFS
Thanks that helps
Hi, to follow up, the striping is vinyl, the dealer is trying to get the name and make of the yellow, if it find out, I'll forward on. All the best.
Reactions: TFS
Did you swap your mirror caps with ones from a Hethel Yellow Emira or did you vinyl wrap them, and if so, what wrap brand and color did you use?
Hi, No, didn't swap the mirror caps. It's a 2026 Turbo SE ordered with the "yellow" option for the mirrors and front and rear center, side edges. It has Llumar Valor clear wrap and the hood/trunk stripes and front side thin lines are vinyl wrap. I've asked my dealer to get the name of the yellow vinyl color.
Thanks. They seem to have done a good job matching the color of the wrap with the mirror caps.
Thanks. Much appreciated
