Steering Wheel Lock?
James DG
Hi All
Anyone using one yet? Any recommendations?
I'm thinking of the Stoplock Pro Elite but not sure if it will fit (although it looks like it will work for pretty much anything).
Cheers
It’s reviewed on here… funny watch tbf
Just to confirm the StopLock Pro Elite fits.
It's best to turn the steering wheel a bit to be totally clear of the centre screen.
Reactions: ADC
Can double confirm... and found that by turning a bit further right, and feeding it through one of the *small* openings, you can properly engage both steel loops with much less hassle.
I use a Disklok see pics
I fit mine downwards, so the lock is on the top left and the bar to the bottom right. Is there any advantage to fitting it like you've pictured?
In short, no there probably isn't any huge advantage ... ever so slightly easier to reach the keyhole and insert / remove the bar while standing outside the car? Can still get into the car while the lock is on? Extremely visible to any reprobates walking past?
(just tried fitting it as you described - set the horn off a bunch of times 😲 :LOL: , and couldn't get the door to close, as the bar fouled the seat bolster... I guess maybe I sit further forward and/or have the wheel telesoped out further 🤷‍♂️ )
lol, I've hit the horn many times doing this - thats an advantage right there
I'll revive an old thread because why not. I have an elite pro, fits lovely!
However, I wanted to ask, where do you keep it loose when not fitted? It slides around in the space behind the seats for me. In older cars I've kept it under the front seat leaning against the back seat, but there's not quite enough room without pulling the seat forward, and don't want it to get jammed either..
I noticed there's the luggage hooks, could maybe tie it to that...
