Smooth Upshifting - Best Speed/RPM per gear
FInWin
Does anyone have any recommendations on what speed or what RPM range I should use per gear for the smoothest upshift? Specifically 1st-4th. I am asking about normal day to day driving/driving around town. For example should 1st be used for 0-20 MPH, 2nd 21-40 MPH, etc.
A smooth upshift doesn't come from a specific speed, it comes from waiting just long enough for RPM to drop. Push in the clutch, and while pushing it in, move the shifter to your desired gear, and gently push against the synchro until it pops into gear, and smoothly let out clutch. You'll have to wait longer for input and output shafts to synchronize if you're shifting across several gears, like 1-4, but for a single upshift, it's really quick.
You can even get an idea of what you're shooting for without using the clutch at all. At some reasonable speed like 40mph, shift into 3rd go into maintenance throttle that's neither accelerating nor engine braking, you can gently pull it out of 3rd without the clutch, and gently push into 4th - it'll pop right in once RPM is correct. This is what you're shooting for when clutching too.
Be gentle, don't force it into any gear and it'll be smooth.
Thank you. I understand the explanation, outside of one item. How do you "gently push against the synchro"?
Imagine you're going from 3-4. Just pull the shifter back towards you, with two fingers, and gently pull until you fell resistance. That's the synchro doing its thing. when the shaft speeds equalize, it'll pop right into gear with minimal pressure.
