Sketchy Experince on Offramp?
luciddaydream
Has anyone else noticed their car feeling a little tricky on off-ramps ?
I’ll be the first to admit I’m not the best driver in the world, but I’d put myself slightly above average...
I absolutely love this car, feel really connected to it, and have a lot of confidence driving it.
This isn’t meant as a criticism..if anything, I’m pretty sure this is more about me than the car...
But there’s one thing I’ve noticed: when I’m taking an off-ramp at a somewhat high (but not wild) speed, it sometimes feels like the car doesn’t settle into the turn the way I expect.
A couple of times, it’s felt a little closer to the edge than I’d like. Thankfully the brakes are excellent, so I’ve always been able to slow down and recover, but today’s experience honestly gave me a bit of a scare. I can’t tell if it’s sliding, understeering, or just something about the way I’m handling it. My best guess is that the g-forces push me sideways in the seat, which makes it harder to keep precise control of the steering and judge exactly where the front is pointing.
It all happens so fast that it’s tough to pinpoint. I’d be curious to see how it behaves in a controlled setting, like on a track. Anyone else run into this?
Thanks
If you’re able to apply the brakes in the turn you are fine. If the car was actually at the limits, applying the brakes would typically bring the tail around into an even more uncomfortable oversteer.
If you are still accelerating hard and you’re feeling understeer just reduce the throttle and the nose will tuck into line.
I don’t know what tires you have, but the Goodyears communicate quite well and give you a nice predictable feeling. With the windows down, they’ll also give you a clear audible feedback as it goes from roar to growl to squeal.
Also check pressures. I’ve found that 26/30 cold works great. The rears heat up faster and will give a 5lb difference when hot. That helps control the understeer.
May also be a factor of the differential pushing power to outer wheel, along with braking inner wheel. If you’re not used to that “yaw” impact, it can feel weird, partially bc it isn’t a direct result of the steering input necessarily
Thanks guys, yeah I guess the main thing I'm saying is -- I feel confident with the car but not in this area. Would be cool to test it on a track and really get to know it.
Doing a track day is very helpful. You’ll learn how it’s going to behave in a relatively safe environment. These cars are sensitive to tire pressure and tire temps. On track I found it understeered early in my first session, then got pretty neutral as they heated then went back to understeer.
I mucked around with pressures, then went to max negative front camber. Next time I went to track it was much better. And definitely better on the backroads.
Oh and if you do a track day, run a few laps to get the feel then disable the nannies. So much better when they aren’t intrusive. Not recommended turning them completely off on backroads.
Can you explain in any more detail what you're doing and feeling? Do you have any other cars to compare to on the same onramp? Do you have experience in mid engine cars? What is the road surface like? What's the camber of the on ramp?
Just taking an offramp at a fast speed but not super-fast speed. Not sure the specific MPH. But a speed that I thought the car could handle, but it didn't seem to be able to. Car just wouldn't handle the turn. Possibly my fault.
I have had posrches, and recently a 992 with rear steering and Im sure could've handled it.. but the lotus seems tobe able to handle turns better in city streets, etc. So its tough to say.
No, just 911's but they are more rear engine.
Just a regular highway road. Not sure on camber.
I guess I'm looking for more detail on what you mean by "handle it". Was it understeering, oversteering, on the way in, on the way out, skipping over bumps?
It was going into a right turn off a highway
I thought it would handle the sharp turn, but I almost drove off the road.
It wasn't able to handle the sharp turn.
So an understeer.
No bumps. Regular highway road.
