Racechip V6 Emira piggy back
OK; how about some details: install problems, running problems, codes; ease of App use, drawbacks, etc.
Sounds promising, somewhat like JB4……………..
Thanks for info………….
Literally 10 mins to fit and the app install is so easy even I managed it first time round. It takes longer to figure out where to fit the box, I chose the battery casing which I did using some self adhesive Velcro to facilitate easy removal along with Velcro tie wraps. Well worth the time effort and expenditure in my opinion.
I just want to thank Steve and Dave in Australia . Thanks from a grateful Pom . I took the plunge and ordered and fitted the Racechip GTS 5 today. The car is truly transformed it really is. I was happy ish with it before but now it’s a much better proposition. I am not a number chaser I will leave that to others, but in terms of drivability and outright performance this option is excellent. I considered the Burger option but the import tax was so high it really didn’t make a lot of sense which is a shame. Very happy with the Race chip option. Cheers for the advice guys and apologies for opening a rabbit hole of differing opinions
Glad you love it. The performance improvement makes the Emira much more drivable. The instance power build up transforms the car. Like you, Im not a dyno type of guy. I prefer to make my assessment by how the car drives. Enjoy.
I just tracked the cable into the boot and secured it there with velcro. Less heat issues, and easier to access if you want to change a setting. It`s the lazy mans option. Reality was I couldnt wait to try it out so I threw the box into the boot and took it for a spin. Did the characteristic WHOOOHA when I hit the gas.
Hey Ian would you mind taking a pic of your engine bay with the racechip installed showing the connectors in use and routing?
I used Velcro tie wraps which have held up well in the heat and enable everything to be removed quickly if required
