Puddle lights in door
Can anyone provide a revised order link? I keep trying to order the ones linked previously on AliExpress and the order won't process. I've tried multiple computers and each time when trying to confirm the order it gives me an order processing error.
Thank you but same problem. I have no idea what is going on. Alibaba works fine, but AliExpress keeps giving me this error. I tried reaching out to them and they said they would investigate but still the same issue.
Maybe certain sellers, or the website itself sees that you're IP is in the US and says, nope not today.
Just added them to mine last night. I love them! Although I did have to swap them left and right because after first install they were upside down. Apparently during manufacturing they got the left and right labels wrong. 🙂
It so simple to fit new ones, literally pop out the old and insert the new in 10 minutes.
Have any of you replaced these?
If so, how did you remove them?
Pop them out from the bottom, or remove the door card and do it from the back?
Hi Corby, did you end up doing this mod. If so, where did you order your new puddle lights from?
I did swap mine.
Got them on Aliexpress.
There are a bunch of different sellers.
I think I paid about $100.
I had some made up from a image I supplied
Still waiting for my parts to arrive, they look so cool! Did you guys have the car on during the swap? Did you disconnect the battery to not blow a fuse? First time swapping puddle lights so I don’t want to take any chances to something that looks simple. Also when removing the puddle light is the wire at the back of the door or the front?
