Pinging (?) high gear in touring mode
Kaz
Try this next time you're out:
Touring, manual...drive to like 50/60 and upshift to 6/7/8 so you're barely over 1500-ish rpms and lightly tip in throttle...barely. Is that pinging? or some...M139 light metallic sound we aren't used to yet? After the tank of gas that came with the car when I first heard it, my shop texted me that they noticed pinging too. So put in a tank of 100 and it seemed to go away. Just filled back with Cali 91 and that sound is back. Interested to read what you hear -
Do you mean 4/5/6 rather than 6/7/8? I was advised to be at circa 2k immediately after an upshift to avoid what’s been described as a rattling or lugging (there are posts on this topic), which resolved it for me.
I think he is referring to the I4 Emira, with the 8 gear auto Box. The comment about manually upshifting is also a clue(I think)
Got it, thanks. (My brain reflexively equates manual with the 6)
He could be having the same experience with the 8 that I had with the 6. I’d be interested to know.
it's pinging...might be a California 91 octane thing, I don't normally lug the engine at such low rpm's but good for people to know to avoid
Hello. Just a general ‘small displacement very high output turbo’ thing - never ever lug a high boost high output small displacement engine as it is more likely to pre-detonate and hurt the ring lands/pistons etc etc. my Civic Type R is OK/happy at 2200 rpm in top gear but no lower (2 liter 306 hp). My GR Corolla Morizo is OK at 2700 in top gear (1.6 liter 300 hp). The GR Corolla is especially sensitive to lugging and it’s no good to do so. I typically don’t let it go much below 3k in gears 4/5/6 ever.
100%! reason I posted is the most people will commute/daily in the Touring mode in automatic, and the programming will go as high a gear as possible and especially on the highway you'll be going 50-60 already in 7th gear and you can hear the engine pinging. Car is much happier near 3k at least...
I just picked up mine 2 weeks ago and noticed this right away. I thought maybe the dealer put 87 in it or something when I picked it up, but 2 tanks of 91 later, it still does it.
I'm hoping after the break in period and then a tune will resolve it.
I think all or most 91 gas I4 drivers have this and just don't hear it, it's so faint. Service never sees a code though they have logged it several times in service history to have it in record in case there are issues later. Maybe a future map update will come for 91 - running a box like TDI/JB4 should get rid of this
In New Jersey we have Sunoco 94 and I run that ..
But if you hear pinging drop it down one gear and see if that stops the Ping..
You have to remember this I4 is only 122 cu in...
That is a lot of work in 7th and 8th for such small motor at times.
In New Jersey we have Sonoco 94 and I run that ..
yep it IS a lot of work for 8 gears, it's just that in Touring mode in automatic you are in 7th or 8th gear as fast as it can upshift...easy to just drive in sport or track now and keeps revs up - and yes it goes away with higher octane gas I don't think the maps on these cars were designed really for 91
Well crap have I been damaging the engine during my entire break in? It’s happened to me almost every drive. I did put high octane in on my third fill up and it alleviated it, but it would still ping just not as much. I would describe what I’ve been hearing as more of a rattle than pinging but it happens just as you guys described. Nothing I can do now I guess I’m at 960 miles so I’ll just drive in sport from now on and try and keep the revs up. I’ll mention it to my dealer when I go in for first oil change. Seems weird to me that Lotus/Mercedes would tune it like this if it was a problem. Guess they wouldn’t care if the problems this caused were to happen after the warranty expired.
I do not believe all high octane gas is equal at some cheaper brand stations..
And in New Jersey only Sunoco carries 94 octane and not every station has it
and some other brands say 91 ...
I know I am only doing touring mode with 750 miles on mine but on some back roads
at 45mph and in 7th gear I do not hear pinging but I still downshift at least one gear to bring up rpm's..
And sure with lower octane you will get pinging but try lower gears ..
And Harley Davidson has a 135 cu in motor in a bike bigger than what drives the Emira.. Amazing !
But all about gear ratios on this I4 and think they should have stayed little lower ratios
on 7th and 8th and not brag Emira can do 180 mph and kept it to realistic 165 to 170 mph..
