We have about 700 tables, with almost everything defined.
It’s straight from the Evora.
Lotus basically took an Evora GT calibration, sprinkled some updates on it, and put it onto a newer chip, then slapped RSA on it for protection (due to euro regs)
This is super impressive. Really well done! Excited to see this this goes!!
will likely have a friend order ecu from a random dealer but we will def provide vin.
We will then have full dynos done. And share. As tfs said, it’s probably reasonable for us guinea pigs to get some Sort of price concession , who are taking some risk to demonstrate the product on a new platform.
tune for friend’s car should have following: 7200 redline, 2.8” pulley, catless headers but 3rd cat still installed, with stock valved catback. Car also has eventuri intake.
Can you do remote tuning session to dial things in further while we are on dyno?
Once you determine pricing, pls Dm me the final amount and also let us know where to send the ecu.
remote / custom tuning is not possible yet.
If you order the ECU and send it to us we will bench flash it for free. But I will need a little time first.
Ok, understood. I’m not sure how fast these ecus will arrive from uk anyhow.
I’d rather put the order in and at least be in the queue. I don’t mind if you end up sitting on the ecu for a few weeks. No rush.
Can’t find your address tho for drop shipping, so pls either send here or via dm when convenient.
Thanks,
Thanks,
please email support@ovtune.zendesk.com we will get you setup
These following is what I need aswel with the mods I have so far on the car.
I have previously had the JUBU440, and currently the JB4 but with your ecu tune I want solely run the flash ecu tune and get rid of 3rd party devices.
The car should have the following:
7200 redline,
2.8” pulley,
I am living in a hot and humid climate especially the summers are hard: 45-50degrees C average between May and August. Currently temps are dropping to high 30s and low 40s but that comes with 85% humidity in these changeover months. November to March are the best months around 30 degrees during day and 20 around night which makes is the ideal months for car lovers.
So im giving this info that you have an idea that my Density Altitude in the summer months can be around 4000/4500ft elevation while on sea level.
Current mods are:
catless headers in ss,
Mid pipe and rest is change to titanium
3rd cat delete,
Milltek valve controller,
GRP high flow air filter,
98 fuel,
If the car runs smooth I am willing to upgrade this mod to 7400/2.6’ pulley after 1000km smooth operation.
Like @NJemira85 said, we would like some sort of discount as ‘testers’.
pls Dm me and also let us know where to send the ecu, I am this weekend in Chicago and could potentially ship it to you on Saturday.
So anyway...
Say we get a new ECU, get VF tuned, and whatever. Is it then a simple matter of having the original ECU on hand to swap back and forth and the original ECU is "none the wiser" that I have a side ECU? Like they won't meet each other or find receipts or anything... right?
So anyway...
That is correct
We are ready to start taking orders for everyone.
This will include full BFlash unlocking, as it is going to be a simpler process.
You can order now.
Ship us your ECU
We will unlock it, and flash the tune of your choice.
From all of our work on the evora we can *guarantee* similar gains.
NOTE, this option does NOT require a you to purchase a new ECU
You can order now.
Ship us your ECU
This is great! Could you explain the bflash part?
We will use BFlash tools to flash it over CAN, instead of our own tool which is by flashing the chip directly.
Just a different process of flashing. Result is the same (Bflash is easier).
You can order now.
Ship us your ECU
Awesome... so once unlocked, it's OBD flashable with the bFlash system? Just trying to get my head around what future potential this could unlock for the owner.
[edit] just saw you answered above, thanks. So is bFlash adding the Lotus G6 ECM to their support with this?
Only bench-flashable.
we will work on OBD based flashing via our own tool, which users can upgrade to at that point.
If you want a BFlash tool for your own personal car..I don't recommend it. They are like $5000 USD.
Apologies if this has already been asked. Can stock motor can go to 7200rpm / 7400rpm without modification?
Yes sir.
Nearly all of our Evora customers run 7200+ Rev limits. No issue at all.
