Loss of interior lights
Gooner
Evening all
Not having much luck…..
Having created a post yesterday about the SRS fault, I now have 2 additional issues.
The first is that I’ve lost the interior lighting. This affects the main lights in the roof. They don’t activate on opening the door and can’t be switched on. I’ve also lost the green illumination that shows when set to auto. The the ambient lighting i.e. that in the footwell, doors handles, cup holder etc, still work.
I’ve also got a rain sensor fault being thrown when putting the stalk to auto for the wipers.
Anyone had either of these issues and can advise at all? The interior lights is a particularly odd one!
I’ve dropped the dealer an email but it’ll no doubt be a while before they can get it booked in and it’s a pain getting there 😩
Booked in for Friday with the guy who did the sound deadening.
Given 4 of the 6 potential locations of the issue stem from the headlining, he says it’s likely to be coming from there and if it is, it’ll be covered by his warranty.
I did however have 2 questions I was hoping someone could answer please:
- What is the glove box switch?!
- Does the rear view mirror use power for anything other than the auto dimming feature?
Thanks
The glove box switch would be the one that turns the light on and off when you open and close the glove box. The rear view mirror also has the HomeLink switches in it.
Sounds like it might have been something the sound deadening guy did.
I thought it could be referring to the opening button, but that still works which tells me it must be mechanical 🤷🏽‍♂️
Do you have the passenger airbag dissabling switch inside your glovebox, and could the fuse be for that?
Good point on the glove box light switch as it could very well be that and would be easy for him to check.
I had thought about the Homelink possibility, but since Gooner is in the UK, I don't think it's offered there but, I may be wrong.
The rear view mirror has usb slot most use for dashcams, so there's power needed there. I imagine the rain sensor is powered there too.
Homelink is available in the UK, I found out at the weekend, that my car has it installed(only took me 3 months to work it out) Now just have to work out what to use it for :)
The USB is on a different fuse I believe. I think it’s the one next to the one in question. I took the 7.5amp out of that slot and tried it in slot 82 which is when I found out there was an issue as it blew straight away!
Interesting... do you mean that your rear view mirror has the 3 Homelink buttons, but they don't operate your garage door, or perhaps you don't have a garage?
I happen to also own a car in Europe (Portugal) which happens to also have the rear view mirror with the Homelink system, but was disappointed to find out that the US Homelink (and garage door systems in general) radio frequency is not compatible with the systems there.
Not tried to set it up yet, but yes 3 buttons. Yes have a garage and will look into it more at the weekend
Homelink works perfectly with my garage door. If you set it up you might need help from someone to press the button on the garage unit & then quickly press the Homelink button in the car to link it.
Just to update, the issue has been found and fixed.
The issue was the wire going into the sun-visor vanity mirror. This is where the installer suspected the issue would be and he was right! It’s very tight in there and whilst it was fine when I left having had the work done, the wires must have been pinched when the visor was moved at some point.
Thanks to everyone for their suggestions and help.
One bit of advise for everyone, the Emira uses micro 2 fuses not standard micro. Maybe I’m the only mug that didn’t know this………. I only found this out having ordered micros that were delivered yesterday 🤪. Micro 2s are not readily available and usually have a 1/2 day wait (in the UK at least). As it was, the installer needed to go to Halfords and buy 2 mixed packs to get the 2 7.5s, which was a very expensive way of getting the fuses needed!
I’ve now ordered a selection of them to sit in the garage at home so I have spares if needed (because Lotus don’t give you any, unlike some manufacturers).
One bit of advise for everyone, the Emira uses micro 2 fuses not standard micro. Maybe I’m the only mug that didn’t know this and I only found this out having ordered micros and having had them delivered yesterday 🤪. Micro 2s are not readily available and usually have a 1/2 day wait (in the UK at least). As it was, the installer needed to go to Halfords and buy 2 mixed packs to get the 2 7.5s, which was a very expensive was of getting the fuses needed!
Nice! Glad you got it sorted.
T
The Homelink Instructions say just point the existing Garage opener fob at the Rear View mirror and press buttons on both. Hoping there is no need to do something with the Garage Unit itself, as I have never seen any buttons on that.
T
Yes I tried following the instructions & pointing the garage opener fob at the rear view homelink button but I could not get it to recognise it. I then used the button on the garage unit (motor unit) to get it to recognise the Emira rear view homelink button and it worked. The button you press on the garage opener unit is usually the same procedure to follow as if you are programming a new fob.
To program a new fob, I just point the new one and the old one. The New one I hold the respective button down for 3secs until the light starts to flash and then press the button on the old remote as I would when opening the door.
There is a procedure to pair a new fob with the Garage unit, if you have lost all the fobs, but the manufacturer allegedly only allows themselves/an installer to do it
Holy thread resurrection Batman !!!
I at last got round to trying to sync Homelink with my garage door opener. Took a few attempts, but at last the Rear View mirror light now says it linked, by being green. However, it does not actually work.
Any suggestions? Seems daft that the Homelink system says the button has been programmed ok, only for it to then not work. Open to ideas on this one as I'm stumped
Fresh batteries in your garage door opener when you programmed your home link?
Less than 3 months old
Its the bit, where the icon changes to green and then does not work, that is confusing me. Implying it has taken the coding, but then not actually transmitting anything
Similar experience; some closure systems apparently require "pairing" of signal by activating signal button on garage door motor-Homelink instructions give the sequence....I had to do this to complete programming for my setup.......
