JUBU cooling upgrade 2GR
hugopanec
Hello guys,
I am looking for a solution to slightly decrease engine bay heat and possibly run the engine a few degrees cooler. If I drive in the city for an extended time, I usually get the engine-reduced acceleration error.
Do you think those 2 products from JUBU could be a good solution and also do you think they would be okay with the warranty? Thanks :)
Thermostat Upgrade: https://www.jubu-performance.com/en/shop/part-jubu_kuehlungsupgrade_2grfe-2305
Hose Kit Upgrade: https://www.jubu-performance.com/en/shop/part-jubu_ladeluftkuehlung_upgrade_kit-2562
These changes are very low cost, but I'm a little nervous about the reliability of that thermostat - however irrational my fear may be.
Also, what would be required to install all of this. Engine out?
I would say that JUBU makes some very quality parts, at least everything I had from them so far.
Changing those parts should be an easy 30-minute job.
Hello guys,
Do you have the i4 or the V6? There's something wrong, your car shouldn't be overheating like that. Is the cooling fan in the front working properly? I'd have the dealer check this out. They can check the fault codes which should let them know what's causing this.
It would take me 30 minutes just to put on some music, get my head lamp, lay out the tools, grab a drink, put on gloves, decide I want a different play list, bathroom trip, and.... decide it's lunch time.
I have the V6, the car is not overheating, it is pretty normal to all the emiras, just want to reduce the temperature in the boot by a few degrees. Other than that my coolant temperature does not get over 90c.
Oh, okay I see what you mean. I got some heat reflect material that I'm going to put on the bottom of the boot area, not in the boot, but underneath, just above the muffler. I'll have to get under the car and remove the muffler to do it, but that's one of two possible remedies. I have a laser thermometer and I'll measure the temp in the boot after I do this to see what it says. I've already done a baseline reading, and with the car fully warmed up, outside temp was 61°F, the temp in the boot was 83°F.
The material I got reflects 98% of the heat, so that should eliminate virtually all the heat coming up from the muffler. If the temp in the boot is still high, or higher than I would like, that means I'll need to put heat reflect mat on the front of the boot enclosure too, the part that faces the engine.
I'll let you know what the results are, and post them in my project journal thread Adding Lightness.
Good luck! I would also try the product I linked earlier since it opens the thermostat a bit earlier and should keep the overall engine temperature a bit lower, prolonging the lifespan of the components.
Pretty sure if you open up the coolant hoses and remove the thermostat you need to rebleed the system which requires a special vacuum bleeder tool. Never done a Lotus (yet) but on Porsches they can be a real PIA to get right. Suspect its no where near a 30 min job.
Also if lower the thermostat even 10-20 degrees I doubt that would even lower the bay/boot heat any. I think most of the bay and boot (trunk) heat is coming from the exhaust/muffler anyway.
Ah, makes sense, thank you for the feedback!
.... just want to reduce the temperature in the boot by a few degrees.
Forgive me if I'm misinterpreting, but I think your exhaust is going to make sure that boot temps stay where they are, regardless of engine coolant temp.
There's heat shield material there from the factory, but I'm not sure how effective it is.
I got some of this stuff: https://www.secondskinaudio.com/heat-insulation/mega-block which I'm going to put above and behind the muffler and the 3rd cat (this pic shows the delete pipe is there).
I wish I had a oil cooler instead of just a water temp gauge. When oil gets cooked it takes a lot longer for the temps to lower compared to water.
I'm pretty sure one of the reasons the boot gets cooked because it has heat coming from both the back wall and from under. But...crucially, it doesn't have any exposure to 'open air' so even with more heat reflective material I think it will just increase the time it takes to get the trunk toasty, not really keep it from getting up to that temp.
Generally, while it does get warm, it's not really any warmer than things left in a trunk with the sun beating down on it for a few hours.
I can't really fault anyone for pursuing options, but for my purposes. If I need something in the trunk 'protected' from heat, I'm either going to put it on the shelf in the cabin, or put it in an insulating bag and manage the conditions that way.
While Jubu makes great stuff I think it is far to premature to suspect cooling problems on the Emira, at least on the V6 configurations. We run these cars on tracks in Texas in 100-110 ambient are temps and typically 140 (60C) air temps above the track pavement. The only coolant thing Ive changed on my 2017 Evora Sport 410 is the installation of the Jubu manual transmission heat exchanger, this unit is just larger capacity than the OE fitment and actually is very similar to the OE installation on the Emira. I will be leaving my Emirs's cooling systems untouched.
btw this is the update Lotus did for the 2026 models
You have docs to back up that this is specifically the changes that were made?
Specifically, a different thermostat and a change to the coolant routing to reduce the function of the charge air cooler to isolate to just that job?
