JUBU Aero
I did it too this week.. love the wing!
The Best looking wing for Sure! Can't wait to see my car next Sunday because I'm installing the CT carbon fiber difusser and side skirts as well.
love the wing but the thought of cutting pieces of my car off scares me way too much to ever attempt
Would love to see those ceiling lights.
How tall is your garage?
What car lift system is that?
Damn. That rear wing install is clean and looks awesome!
The garage isn't finished yet, nor is the lighting. It was awful two years ago when we moved in. Everything has been redone. Tomorrow a second lift will be installed, and I'll take some pictures this week.
I can't even describe how sexy this wing and louvre combinayion is!
Thanks for the heads up on sealing it and will place drain holes under trunk lid because water was in there even before this was installed.
Those to screws at the ends don't allow the water to fully drain.
Now that you've seen all 3 parts and how long it may take to get them. Which ones are you buying or not buying and why or why not?
I saved 8 lbs by removing rear glass and placing the louvre for engine heat extraction.
But it probably ends up gaining that weight back with the addition of the spoiler and large splitter. I’ll take the down force any day even if I had to add weight. If you’ve ever tracked over a crest before and after aero improvements, you know what I mean.
I’ve seen some cars oversteer in video around turns, but the secret is never lift so the weight doesn’t transfer to front tires.
And heat sink has caused my challenger to go into limp mode before I cut and placed louvres on each side of my hood to let the heat escape. These 3 parts are a need, and not a want, if you are serious about tracking your Emira. And they look sexy too!
You will have to cut and trim the carbon fiber JOGON pieces on sides of louvre, otherwise they won’t fit because it’s tight.
