i4 Weird Jostling at Low Speeds
EatAHelicopter
Active member
I've had my Emira for 3 days now and I'm experiencing a weird jerkiness, that's kind of hard to describe. At low speeds (below 20mph), I cannot drive the car smoothly. The car jostles forward and backwards, almost like someone was lightly tapping the brakes. Especially when to decelerating to a stop or just closing the gap between me and the car in front of me in traffic, it's very jerky and not smooth driving at all. I didn't experience this when I test drove one, but that was a touring suspension and I had it on sport mode the whole time. I'm still in my break-in period, and I have sports suspension, so I'm wondering if this is just a quirk of touring mode or is someone is actually wrong with the car?
Thanks!
Is it this issue reported here:
Doesn't sound like it. It's not revving or launching me forward, it just jostles back and forth essentially.
"The car jostles forward and backwards, almost like someone was lightly tapping the brakes."
My sports suspension does not affect the driving like this. Forward progress is smooth at low speed.
I drove the touring and sports suspension back to back at test drive, I don't think there's much difference between the two and nothing like what you describe.
It sounds like there's something wrong with your car - I'd take it to a dealer or trusted local garage to be checked out.
I think the jostling is essentially what we've been discussing - just using somewhat different words. I've met two other i4 owners in person who have brought this up (without me prompting). Some claim it's specifically in second gear at some RPM and only in Touring mode...but for me it can happen in any gear (usually 1 through 3) at speeds under 40 mph. It's infrequent and inconsistent, easiest to replicate in city traffic or stop and go on the highways (such as commute hours). It hasn't happened more or less often since break-in (at 1,5XX miles now) and the transmission in full automatic worked great on the race track. No issues on backroads either.
Suspension type shouldn't matter unless it's on a road surface that's causing you to unintentionally jab at the throttle with a bump (I have had this happen over a speed hump) and it almost exactly replicates the jostling.
That's interesting. I haven't taken it off tour mode yet, but for me it seems to happen most in 2nd gear. I'll have to see how it behaves once I'm in sport mode.
