I4 tuning box development - who wants one?
Interested in a dyno proven i4 tuning box for approx £400
  • Total voters
    28
May I ask how did you come up with 519bhp?
The 93 tune is 444 at the wheels. That calcs out to a 15% loss between crank and wheels which is a pretty standard assumption for loss.
Interestingly though they got 387 at the wheels for the base tune which is only a 4% loss if they are actually 400 at the crank. Applying 15% to the 387 is 455 which I don't think is realistic either. No way Lotus is giving out an extra 50hp without claiming any of it.
You always compare from the baseline. Different dyno gives different result and drivetrain loss is always just an assumption.
Dynojet always records higher.
Yes I included the standard drivetrain loss to get bhp. Actually it may be less than the 17% I used to estimate as it is a mid-engine car. However that said it almost double what TDI got out of their system
It was a T45
However a friend mech of mine said that could be that the bit may be slightly thinner then what's sold here although the same size technically . There was also another needed to remove the ac that has a torx bolt. That was wrong as well. I think it said a 10 but it was a 12.
Could I ask what type of ratchet wrench you used?
I attempted the installation today, but I found it very difficult to access the pulley with a ratchet in order to release the AC belt.
It was like a mini breaker bar ratchet. A regular one didn't have enough leverage
