Goodwood - updates and info
EspritGuy
Emira Addict
DFW
Unfortunately I don’t think that’s how it works, wheel offset is defined by the offset the hub surface mounts to the wheel away from the centerline of the wheels.
So assuming the oem Lotus wheel is a 20x8.5 +55 and you move to a 20x8.5 +30 BBS with a deep lip (deep lips aren’t really possible with high offsets). You’ll introduce 25mm more positive scrub radius to the car which is going to be noticeable at the steering wheel.
Deep lips sounds kinda racy........
912Matt
Stamford
https://youtu.be/pZra8dmWC8w
Here's a link to the video I took of the exhaust at Goodwood. It's nothing ground breaking but hopefully it's useful to anyone that hasn't heard much of it up close
Not sure if this will work, but have tried to attach a bit more exhaust porn from FoS yesterday
Edit: That’ll be no then, apologies 🙄
Edit 2.0: Have now uploaded to Youtube
Porter
tap tap... is this thing on?
DC/Virginia, USA
For US cars the plinths are a dealer fitted item, as some states don’t require a front plate.
This is great news. Many US sports car owners who live in "front plate" states also avoid the factory mount, and often will attach a plate on a carrier that screws into the front tow hook location.
paul c
Lymm cheshire
Riding up the hill in the car was fantastic. The seats are very supportive, decent amount of side bolster for brisk cornering. Acceleration is rapid and pretty linear from the SC, it pulls hard from low revs and keeps going. Great V6 noise, even with windows closed and wearing a helmet. Gearchange looked fine and had to be done deliberately, like in an Evora. Grip was very good, even though Cup2s weren’t fully warm, and good precise turn in. The hill was dry and is smooth tarmac, so the slight downsides of Sport on uneven surfaces not apparent. Brakes were particularly impressive, even better than Evora.
We got loads of attention while waiting to start, lots of people taking pictures, waving, chatting.
Internet connectivity has been very patchy, so I haven’t been able to post much. I’ll do more when I get home tonight.
DJS
London
Question for those of you that went to Goodwood……
What manufacturer stands drew the biggest crowds?
Was the Lotus stand in the mix?
Speedluvver
UK
Definitely (on the Friday) - I would say it was one of the busiest... Porsche and BMW of course were also busy but no more than Lotus..
vantage
Los Angeles, CA
Bonnet seal: it looks more obvious in photos than in real life. If it hadn't been on my list of things to look at I doubt I would have noticed. On the Goodwood cars it's slightly recessed whereas earlier pictures showed it sticking up out of the gap and so looked wider. The gap it seals is wider than some of the other panel gaps, as it needs to hinge here for under bonnet access. I think they could have found a way to make the gap narrower and it may be possible to adjust the bonnet to reduce it. The seal is apparently for aerodynamics (perhaps there's some wind noise without it?) so I think removing it will be feasible and unlikely to cause issues.
Throwing this out there, but the solution might have been to hinge the lid at the windshield side, like a normal bonnet. As it is, the seal was added after the fact. A windshield side hinge might make it harder to access what is beneath the bonnet, depending on the design.
TomE
TomE
Surrey, UK
  • #369
$203k or £165k and not road legal
