Custom Floor Mats For Emira
Do you have the screw or post type of anchors? It could be that one of those types results in less pronounced bumps when installing these mats over them.
I think Lotus switched over to the post stye not long after they started delivering to the US - I have seen some that have the screw type, but most have the post type. I agree with @jetblast - I have the diamond pattern w/ the post, and it is not noticeable at all. I wonder if the Modern Line type of mat is thinner, and that is why it is so prominent?
Here’s a picture from my passenger side post type anchor.
so it appears the newer post-type anchors results in the bumps in the witamats once installed?
I ordered them last night, the modern ones, with the Emira stitching double mat. I'll post some photos when they arrive in about 4 weeks or so.
looking forward to it, planning on getting a set as well
A request for 'rubber floor mats you can hose down'.....darn, I must have mis-moused onto an F150 Forum.....sorry, my bad :oops:.
Witamats’ double-layer mats can be easily rinsed off with a hose.
Here's a pic of it installed. I've also included a picture with bump highlighted.
That’s because the single-layer Modern Line is thinner. The Modern Line Double Layer and Diamond Line don’t have this problem.
Also, since the single-layer Modern Line doesn’t have any detailed patterns—just simple lines—it tends to show dirt more easily. That’s why we usually recommend going with the double-layer Witamats.
They should be arriving Friday. Fingers crossed, the car is ready to come out of the shop on Friday too.
Please let us know when (or if) the modern line will be offered for the Emira. Thanks.
