anothersportscar
- Dec 7, 2023
- 11
- 4
Just a question to see if anyone else has clutch clunk on their Emira.
When the car is switched off and the clutch pedal is operated everything is fine. If you fire it up, car in neutral and operate the clutch pedal normally there is a noticeable clunk from the rear. Even using the clutch slowly you can hear it and when changing gear whilst driving too. It wasn't there before (or at least I never noticed it) and seems to be getting worse, it has appeared in the last couple of hundred miles, now over 3K. Anyone else? TIA.
