Thanks for the writeup @Joel and @somer82.
For a two channel camera can it be mounted to the rear hatch glass at the top? How long of a four-conductor wire do you think is needed to go from the boot battery location to the windscreen?
I'm looking at installing a thinkware u3000 and battery so it's rear fuse box to the rear mounted battery pack, then four wire to the windscreen, and from there back to the rear camera. Just trying to plan things and this is definitely a stretch for me.
First up, trying to get the toeboard off to get to the fusebox. For some reason this proved very difficult in my car. Likewise, getting it back on also proved very difficult. Probably the hardest bit of trim I had to remove throughout the entire process, which is surprising since it's "user serviceable" right? Did others get theirs on/off easily?
Seems there's a lip it clips underneath on the bottom side which I think was causing me issues, as well as some ill fitted carpetry.
Once I'd got into the fusebox area, I realised my battery was never going to fit!
Unrelated, but do none of the cars come with tweeters? Is this a mistake?The manual makes it seem easier than it actually is (VOE).
The upper clip is captive (I think to keep the trim in place if the curtain airbag goes off).
The trim will pop out about an inch and then get held in place but the clip is in a slot in the trim from which you can pull it upwards and out with a trim tool or similar. You can then extract it from the A-pillar for re-fitting. The lower clip comes out fine.
I’ve had mine off several times in the never-ending saga of my windscreen replacement.
(I’ll bore you all with that story if and when it reaches a conclusion. I’m currently waiting for Autoglass to schedule a fourth attempt).
While they were off I filled the unused tweeter hole with some handily same-coloured foam.
They do, they are just not in the A pillars. Those empty slots are for when the base audio system comes along.Unrelated, but do none of the cars come with tweeters? Is this a mistake?
That panel is a pita to put backI'm wiring up a blackvue dashcam today and decided to use the footwell fusebox. Man, this panel with the four quarter turn screws is not easy to get out. Maybe it'll be easier if I loosen all the glovebox screws and shift the glovebox out of the way (not remove it completely or disconnect airbag cable. Routing the camera wire from the rear view mirror down to the glovebox area was pretty simple. Just push the wire into the crack and lift the edge of the trim (headliner or a-pillar) until the wire falls behind the panel.
Is the fuse box behind the passenger seat easier to access?
I’ve heard this from everyone, I look forward to this little slice of hell.I'm wiring up a blackvue dashcam today and decided to use the footwell fusebox. Man, this panel with the four quarter turn screws is not easy to get out. Maybe it'll be easier if I loosen all the glovebox screws and shift the glovebox out of the way (not remove it completely or disconnect airbag cable. Routing the camera wire from the rear view mirror down to the glovebox area was pretty simple. Just push the wire into the crack and lift the edge of the trim (headliner or a-pillar) until the wire falls behind the panel.
J | Dashcam for the Emira | Lotus Emira Electronics | 207 | |
Radar Detector hardwire? | Lotus Emira Electronics | 17 |
