The manual makes it seem easier than it actually is (VOE).Thanks, that makes me a little more confident in removing it!
Was there unconnected wiring in place for the tweeter?While they were off I filled the unused tweeter hole with some handily same-coloured foam.
Nothing visible.Was there unconnected wiring in place for the tweeter?
The carpet didn't seem to be fitted correctly and was making it hard to get the board out, bit of pushing and the carpet tucked under properlyWell this is frustrating, I can't even get the passenger footrest off! I've undone and removed the clips but the bottom won't budge, seems it's being held in by a bump on the left and then a bump on the right at the bottom, pretty sure it shouldn't be this hard![]()
Possibly, though it would have to be quite a bit smaller. The back wall is full of cabling so the only place you can really attach to is the top of the fusebox, which not only isn't level, but it's also not that deep. It really is quite cramped down there to be honest.Excellent tutorial @Joel ! Do you think a smaller battery would have fit there?
Got it thank you, I think I’d maybe remove some rear cabin paneling and see if it would fit out of sight there.Possibly, though it would have to be quite a bit smaller. The back wall is full of cabling so the only place you can really attach to is the top of the fusebox, which not only isn't level, but it's also not that deep. It really is quite cramped down there to be honest.
Brilliant! Out of interest, where is this page copied from?
@kitkat I too am curious - where are you getting those pages from? Is there a service manual available somewhere for download?Brilliant! Out of interest, where is this page copied from?
Correct, many want parking mode recording.Pretty serious install - isn‘t the USB port in the mirror for a dash cam? Does it not work?
Is the purpose of this install to have it running while the car is parked and switched off?
And not all dash cams can run off of 5v power from a USB as wellisn‘t the USB port in the mirror for a dash cam?
J | Dashcam for the Emira | Lotus Emira Electronics | 207 | |
Radar Detector hardwire? | Lotus Emira Electronics | 17 |
