ULTRAdisc by Girodisc: Best Prices, Free Shipping & Emira TShirt
shinoo
🏷 Supporting Vendor 🏷
Free Emira T-shirt with every purchase. Plus we offer unique hat colors - Gold or Silver! Order: HERE
Excellent Performance & Excellent Value! The Emira ULTRAdisc are the most proven, long-lasting. lightweight, 2-piece rotor solution on the market. They work perfectly with your stock calipers, on and off the track. We partnered with Girodisc in 2005 to develop what has become the best 2-piece rotors available for the Lotus Elise since 2005 and Evora, S 400 & GTs since 2011.
Purchase Options
  • Choose either Gold or Silver hats
  • Gold will be limited
  • Silver will be our standard color
  • Front (pair) or Rear (pair):
    • Price is per axle set (2 rotors)
ULTRA lightweight
  • Anodized aircraft 6061 T-6 billet aluminum hats.
ULTRA long lasting
  • Slotted, not drilled
    • Clean rotor-pad interface and maintain maximum grip surface.
    • Will not compromise structural integrity like drilled rotors that tend to crack.
  • High carbon-iron rotor
    • Stable thermal properties.
    • Longer wear characteristics.
    • Zinc plated for corrosion resistance.
  • Extremely high street mileage
    • Logged 20,000 + track & street miles on one set of similar rotors.
  • Run on track in extreme conditions
ULTRA proven
  • On the market for the Lotus Evora since 2011 and Elise/Exige since 2005.
  • Tested on the road & track.
True floating rotor = With No rattles or Uneven Wear
  • Cadmium plated alloy bushings.
  • Grade 12.9 cap screws with spring washers.
  • More effective at reducing heat than a simple 2-piece rotor.
  • Spring washer provide float & control
    • No rattles
    • Even wear
Ultimate Cooling = Reduced Fade
  • Directionally curved vanes.
    • Act as a centrifugal air pump to actively move cool air through the rotor.
    • Quickly removes heat that causes brake fade.
Model Compatibility:
  • Emira V6
  • Emira i4 Turbo
Order: HERE
If you have not heard of Girodisc, watch our Tech Seminar video from earlier this year: HERE
We have worked closely with them since 2005 and the owner is a good friend of mine. We also purchase the rotors directly from them - all other vendors buy through distribution. Since we buy direct, we can also get special colored hats and additional performance needs - special rotor plating, etc.
what is the value of the emira t-shirt
$34, high quality long sleeve, plus...learn more: HERE
Reactions: Kaz
