Service at Toyota
leofin
As there is no service center anymore in my country I’m considering Toyota service as an option.
Does anyone have the list of spare parts that need to be changed on a regular service?
You'll be changing the oil and filter on a regular basis and that often happens during any dealer service. You mention Toyota so I'm assuming you have a V6 with the Toyota engine. Here's a Forum thread giving advice on the appropriate V6 oil filter:
I purchased a case (10 filters, if I remember correctly) from my local Toyota dealer, at a discount. If you're getting the dealer to change the oil for you, they should do so, using a filter you supply. I'd suggest you change the oil plug ring each time, as well.
You can also buy your own oil, which will typically provide further savings. The manual specifies the oil type but there are Forum threads where people describe the other oils they use.
Other than those 3 things (filter, o-ring, oil), there's not a lot of "spare parts" you'll regularly have to replace. You might consider topping up your own fluids (windshield washer, radiator...are the more common ones) and telling the dealer they don't need to check any fluid levels (avoiding a dealer charge).
Without access to a local Lotus dealer, I'd encourage you to DIY as much as possible, perhaps starting with an OBD II scanner that works with the Emira, so you can investigate any codes that come up, then search this Forum for helpful advice. The second scanner I purchased worked the best, since it lists "Lotus" as a car manufacturer in its software. It was also much cheaper than the first scanner I bought. The BlueDriver OBD2 scanner is the one I recommend for the Emira. Amazon sells it, so it's easily obtained. Others are happy with it, and it's simple to use. You'll need to download an app on your smartphone, but the app is free. Good luck!
Thanks. I will visit Toyota and look to order the OBD scanner too!
There is one good mechanic of supersport cars nearby, maybe he could assist on making a list of spare parts that would be needed on a yearly basis.
I track the car once a year only, so it should last pretty well without major issues. Toyota engines are supposed to be reliable!
FYI, here's an older thread setting out the UK recommended service requirements for the V6 Emira with a standard transmission. You'll see mention of brake fluid and some additional filters, after the first recommended service:
Up to you if you stock up on filters or anything else called for in these later service intervals. You mentioned tracking your car annually. I had to change my brake fluid for the club that organized my last track session, since my next-to-new brake fluid (very little mileage on car) was older than 6 months. I'm unsure of your track requirements. I also purchased in advance, new brake pads (front and back), knowing I'd demolish a set on the track. You might want to consider brake pads, if you're tracking and looking to stock up. Then there's tires (sigh), which is another story and people sometimes don't have storage room for them or generally only buy them when needed, due to their cost. Hope this helps.
