Road trip in area without Cell coverage?
Wiz33
Been watching the Everyday Driver trip from Utah to Sonoma Raceway and thinking about doing a reverse from the San Francisco Bay Area to at least the Nevada part. I would assume a lot of the side road and smaller highway they went through probably will not have Cell coverage or very spotty at best. Have anyone done something similar and what kind of preparation did you do? Not planning to do anything crazy but with the Emira, there's a higher than average chance of needing outside contact in case of problems. The only solution I can see is a Starlink mini with battery setup. Have anyone use something like this. Is there other options (rental)?
If you have an iPhone 14 or newer you already have emergency satellite access.
For Maps at least Google Maps allows you to download parts for offline availability
The iPhone can work for regular texting, not just emergency access, though I'm not sure if this is limited to just your emergency contacts. Receiving replies is a manual process though, you need to be pointing the phone at the satellite. It works, but is not as convenient as a Garmin InReach which is more of an 'always on' connection and something that works great for texting anyone (you can pair it with your phone to more easily write and read texts that way).
Yea and I plan to have old fashion paper maps with me but it's more about needing roadside assist as the Emira does not have a physical spare and not punctures can be fixed with a patch kit.
I plugged a nail hole in my Evora's rear tire in the parking lot of a La Quinta Inn. It can easily be done.
