No reverse indicator, lights and camera
Shahaf2911
Well as the title describes when I put in reverse (v6 manual) theres simply no response from anything, the car does go into reverse and any other gear without an issue, the fact that all 3 don’t function (display R gear indicator, back up camera & reverse light) I think it might be the reverse light switch in the gearbox ? Anyone has any other ideas ?
I did manage to see a post in lotustalk about a guy with an evora that said it’s the same part as Toyota equivalent.
Thanks in advance
Happened to me as well, it's a sensor that tells the car the gearbox is in reverse.
Dealer was able to fix it under warranty.
Surprised I’m not the only one, quite an odd part to fail, do you happen to know how did they access it ? (From the wheel well or underside, I doubt it’s doable from the engine bay)
Appreciate the feedback
No idea honestly, I just dropped it off at the dealer and picked it up a few days later.... And it never reoccurred.
Oh got it, the camera and everything just came back out of nowhere which I assume implies that it’s the sensor, I’ll get the Toyota equivalent and give it to my mechanic, no dealer here.
Thanks for the help.
I’ll update if the Toyota part ( old: 84210-12040 new: 84210-52050 ) if anyone ever encounters the same issue.
