Key is locked in the car
That is not a cheaper option
Thanks--it's a bit quirky.
UPDATE: AAA (US) came and it took an hour but managed to insert a slider in by separating window with air pump. Door opened, key fob obtained with next issue: the car is not responding to the key fob (will obviously replace fob battery to see if that's the problem) so car won't start. Trying to figure out where the electronic fob activator is in the car. Some info says door handle (no), rear cup holder (no). Back to quirky-town but very happy to have the key out of the car....thanks guys.
According to the manual, it is in the center console as Eagle7 stated. Are you getting the "Key not in car" message? If not, you might have something preventing the car from starting not related to the key detection.
Have you tried a battery disconnect and reconnect? Had to do this a few times on mine prior to a sw update seemingly fixing the issue.
I think you have to place the fob "at the back" of the bottom of the console (see attached). I've done it when unlocking the car with the blade key to turn off the alarm, and it works.
My car doesn't auto lock. I would like that feature.
Weird, mine seems to.. Well, let me qualify that - if I unlock the car with the fob and don't open the door for a given period of time it will re-lock itself. Might not qualify as auto-lock, but what I have observed..
Yep, mine does this too. If do open the door, then close it again, it does not then auto lock
It’s all in the handbook.
Also, opening the drivers door turns on the car but opening the passenger door doesn’t, which might help save battery if you’re not going to drive the car.
But then how to explain why the car locked itself with the key inside? For the key to get inside in the first place either door must be opened first. The auto lock feature described in the manual assumes that the doors are not opened for a period of time after hitting the unlock button on the key fob.
