How low to go with GRP lowering kit and spacers
JKP
Hi All -- I just received my lowering kit and 12MM spacers from GRP. Does anyone have feedback to offer on their setup with these parts? Specifically, how low did you go and any rubbing or other issues with scraping, etc.?
Limiting factor will be the rear axle boots, give it 2-3mm of clearance. You’ll see what I mean when you install it.
Reactions: JKP
Dont go too low.. as kitkat said keep a clearance. I went with Lotus to fix it, my friend* went with another company and they went too far and it broke all the 4 axel boots after a month driving.. it was an expensive fix by lotus
Dont go too low.. as kitkat said keep a clearance. I went with Lotus to fix it and my griend with another company and they went too far and broke all the 4 axel boots after a month driving.. it was an expensive fix by lotus
Thanks FST, much apprecaited! I definitely would like to avoid an expensive fix!
You won't get to low with this coils, maybe a 1/4", had mine for about a month at only a 1/4 drop it shredded a cv boot!!
Switched to Nitrons..
