For Sale: JUBU Performance ECU for Lotus Emira (440 Power Upgrade)
Nba19002
Active member
Price: $2,500 OBO
This is a JUBU Performance ECU for the Lotus Emira V6, purchased in June 2024 and configured for a 440 hp upgrade, 91 octane fuel, 7,000 RPM rev limit, and 3rd catalytic converter delete. The unit is in good physical condition with no visible damage. It was removed from my vehicle following an engine failure and has not been used since. JUBU is an Austrian company specializing in performance parts for Lotus vehicles, and this ECU is based on Syvecs technology. It was shipped to me in July 2024 and installed in August 2024.
Important Disclaimer:
This ECU is sold AS-IS, with NO WARRANTY, NO RETURNS, and NO REFUNDS. By purchasing, you acknowledge that you have read and understand the full details of my experience below, including all documented issues and the potential risks associated with aftermarket tuning. Installation and use of this ECU may void your vehicle's factory warranty, bypass stock safety features, and lead to performance inconsistencies or mechanical failures. I strongly recommend professional installation and tuning by a qualified technician familiar with Lotus Emira and Syvecs systems. Buyer assumes all responsibility for compatibility, performance, and any resulting damage to their vehicle. I am providing this full disclosure to ensure transparency and avoid any disputes. Please conduct your own research and contact JUBU directly (info@jubu-performance.com) for any firmware updates or support before making a purchase.
My Experience (Factual Summary Based on Documented Communications):
I installed this ECU in my US-spec Lotus Emira in August 2024 and used it for approximately eight months (until May 2025), alternating with the stock ECU for comparison. During this time, it functioned as intended only a handful of times (about 5 out of 50-100 drives). All issues below were absent with the stock ECU and these issues were reported to JUBU via email and WhatsApp, leading to five remote tuning sessions (September 2024, December 2024, April 2025) and one in-person tuning visit (October 2024). Despite these efforts, problems persisted. Here's a chronological summary of the key issues I encountered:
- August/September 2024 (Initial Installation and First Tuning):
- Power cut/interruption when shifting from 1st to 2nd gear after hitting the rev limiter (reported 8/29/24).
- Audible beeping noise from speakers at >70% throttle (intermittent; reported 8/29/24, resolved temporarily after tuning).
- Frequent stalling in Touring mode when coming to a stop (revs dropping too low; reported 8/29/24 and 9/4/24).
- Inconsistent air conditioning (worked briefly then failed to cool; reported 8/29/24).
- Throttle mapping delay in Touring mode at low revs or from standstill (reported 8/29/24).
- Power felt flat around 4,000-4,500 RPM (reported 9/4/24).
- Stalling while idling (reported 9/4/24).
- Drop in torque/power between 3,500-4,000 RPM after tuning (reported 9/13/24).
- October 2024 (In-Person Tuning in California):
- JUBU team visited for on-site adjustments. Temporary fixes were applied, but issues like stalling and power loss recurred shortly after. JUBU programmed a launch control mode for my car, which they suggested I test immediately after the on-site adjustment visit in October 2024, with a JUBU representative present in the passenger seat. During this test, the engine bay and cabin filled with thick black smoke. JUBU attributed this incident to a factory clutch issue rather than a problem with the JUBU ECU.
- November/December 2024 (Subsequent Tuning):
- Beeping returned during full throttle (reported 11/20/24).
- Power drop/loss between 6,000-7,000 RPM (timing/knock issue; reported 11/20/24 and 12/1/24).
- Limp mode after revving to redline (revs limited to 4,500 RPM, check engine light on; reported 12/1/24).
- Power loss above 6,000 RPM persisted after tuning (reported 12/4/24, temporarily fixed but returned on second drive).
- April 2025 (Final Tuning Sessions):
- Periodic stalling in Touring/Sport modes when stopping or engaging clutch (reported 4/3/25 and 4/24/25).
- Timing issue/power loss between 6,000-7,000 RPM (reported 4/3/25).
- Low RPM instability (revs dropping to ~500 RPM when stopping, sometimes recovering; reported 4/24/25).
- Limp mode during drive (revs limited to 4,500 RPM, stalled afterward; reported 4/21/25).
- Uneven idling and rough starts (ongoing).
- Pops and bangs reduced, but idle issues in Touring mode remained (reported 4/24/25).
- May 2025 (Engine Failure):
- After ongoing knock and timing issues (persistent between 6,000-7,000 RPM), the engine failed catastrophically. Lotus technicians found metal shavings in the oil, indicating severe internal damage. A full engine replacement, supercharger, and clutch components were required (clutch showed hot spots and damage).
JUBU suggested firmware updates for non-EU cars to address CAN bus bugs (e.g., auto-hold, park brake), but these did not resolve my core performance issues. They also denied the ECU could cause engine or clutch failures, attributing them to Lotus defects or user error (e.g., oil issues, track use), none of which applied to my vehicle (regular oil changes with recommended grade, no track use).
Contact: PM me, Serious inquiries only, happy to answer questions based on my experience.
Appreciate your transparency and recount of your experiences. Extremely sorry to hear about the unfortunate events.
Welcome to the club 👏🏼👏🏼👏🏼👏🏼
Thanks for sharing this valuable info… this confirms 100% of my findings before shared on the forum.. but I was made silenced by JUBU and treathened with a court case. Im glad I kept all the accusations made to them which was shared with me via PM… those people did not want to share it openly on the forum but I did!
I think we should start collectively a court case against Jubu for effing up our cars. Plug and play and remaining stock operation my *ss.
I think if I was impacted and was threatened with legal actions by a small Austria based company if I shared my story it would only motivate me to spread the word farther. I really doubt Jubu has the time and funds to file a suit in the U.S. - particularly a winning one.
Jubu doesn’t have asset in the US. So it isn’t fruitful to sue them, unless you want to sue them in Austria.
If they really sue you, start a donation campaign somewhere. I pledge $1K. I hate bullies like that.
Well they have threatened me to the bone that I shall remove all ‘false’ claims on the forum.. I had documented everything. I then rest my case because people were afraid to talk publicly but shared all their coms and failures to me via DMs so the support was there but not openly.
I mean I would not take it to a court case because we have settled, they took their product back refunded me the money except the shipping and import duties, I've deleted everything and rest my case.. im done with them.
But I am glad other people start to share their stories now.. i leave it with them.
Price: $2,500 OBO
Really sorry to hear this. I know you were part of the first group with me. I hope your next mods go way better!
@sbproducer smoking hot black smoke deal!
I hope you do realize that more than a handful of people on this forum have had serious issues with their Emira including but not limited to their car constantly at the dealership, parts failing over and over and waiting extended periods for parts shipping, lack of customer support from Lotus itself and/or dealerships, VF Tuner and others debating lemon law recourse, paint bubbling, Lotus dealerships charging ridiculous prices for oil changes, etc etc etc.
They might as well be the same company. Yet you don't have the balls to stand up to Lotus.
I don't know what your issue is with me but I just call it how I see it with the courage to admit when I'm wrong.
I think it's important to consider how frequently people drive their cars and how hard they push them. It's relatively easy for someone to install modifications and rarely drive the car, potentially never encountering any real issues. At this point, I believe we would benefit from more comprehensive data on each incident (since we're currently working with limited information and making educated guesses).
I just pinged you so you could jump on this deal quickly before anyone else does.
Bro @kitkat has kidnapped multiple lotus execs per paint blister. Even for other people’s cars. He’s like the Batman of Lotusdom. Not just Jübü.
KatMan?
He’s too modest to brag about this himself that so I will.
He is nightmare fuel at lotus.
He does a lot of questionable stuff, but his balls are beyond reproach.
Guys.. look. I'm trying to contribute the best I can. The more you guys think JUBU is risky, the more I should be praised for having the nads to do this for science.
