Emira Key Blade
Beachbum
I asked this as part of another thread, I am hoping making it a separate thread, someone may be able to provide an answer.
Anyone know which part of the Geely parts bin the Lock/Keys come from on the Emira?
I need to source a new blade. Lotus want crazy money, but if it turns out to be a volvo(?) key or the like, then it will be a lot cheaper to source separately
I think it’s the blade he’s after. It doesn’t say in the advert that that is included with the fob
Yes, just the blade, already have the fob.
Getting the key cut using the 1 blade I do have, should be fairly cheap, so long as I can find out which manufacturer provided the Locks/Keys
Here's what I could find for you with some part numbers:
Thanks kitkat. Now I just need to find where to obtain a blank from, as Lotus are charging over £500!
I'd email the aliexpress seller and ask if their keys come with a key blank. Part of the spreadsheet seems to indicate you can't get the key blank through after sales department, meaning maybe you can't get it at all.
If you do contact the seller, I'll go in and have one and halve the delivery costs.
I will continue to try and find out which manufacturer they are sourced from
No problem. I’ve emailed one supplier on Aliexpress that appears to to do a number of different key blanks, including Geely. Will let you know if/when they come back to me.
