Buzzy Blarp Sound when Engine Braking
Jinba ittai
Who is hearing a buzzy blarp sound under engine braking? Could also be described as a half second fog horn sound. Anyone know what it is?
To be clear engine is braking not breaking. Don’t know if I can edit the title at this point.
Copying my answer from the other thread:
Yes! Since factory. No one came up with an explanation yet and I fear it's the clutch.
I have one month left for warranty and I swear to god if the clutch goes next year I'm driving up to Hethel (if someone is left there by then..)
A theory I came up with, no idea if mechanically sound:
It almost sounds like the clutch slips as it starts to accelerate the engine to match the gearbox. I get this sound primarily when I don’t rev match properly when down shifting. With rev match I haven’t ever heard this. I cannot force it to happen however, so I couldn’t show it to the mechanic yet.
Now that I'm writing this I'm not sure if the sound emits while the clutch pedal comes up or even after the clutch is fully engaged.
If it’s in the transition phase it might actually just be the clutch slipping, whether it should sound like that or not I'm not sure
I think you’re right that it’s clutch related as it happens for me on downshift. If it’s the sound of the clutch slipping it’s unlike any other slipping clutch I’ve ever heard. Seems like the vibration is at just the right frequency to cause intense resonance on something.
Also copying my response from the other thread - hopefully provides some additional context: It's especially noticeable to for me at low speeds / low rpms while decelerating, maybe because the engine isn't loud enough to cover up the sound.
Sounds like a buzzy blarp sound, lol. How's that for a description?
I was initially relieved that this may be a common thing. However, it might just be the three of us…. I will continue to monitor and hope it’s nothing. Maybe work on better rev matching.
I believe I have heard something like this too but very infrequently. Only happens for a very short while, at low speed and low revs under a bit of engine braking. Also seems to only be when I am first setting off - so when the engine is cold. I thought it might just be the rear brake pads rattling a bit as the engine judders under engine braking.
